Strength of OSB v. 2X lumber
Joe Pack
I need to reinforce two floor joists. I can use 2x10 material, or I can use one or more layers of OSB sandwiched with construction adhesive. The OSB is more flexible put in place in 1/2" layers, then glued/screwed together and into the original joist, which makes the installation easier.
How would the on-edge strength of two layers of 1/2" OSB glued together compare to the strength of one 2x10 SPF?
Re: Strength of OSB v. 2X lumber
FredD
On some remodel job's we did that extended the living quarters over the Garage,we had to follow the UBC on doubling or adding 2x10's under walls that were added above the Garage ceiling and were parallel to the ceiling joist's in the Garage.
This requirement consisted of using 1/2" bolts staggered 24"on center through the lamination. The added joist was always full length ,one piece.
FredD
In theory, only the part of the OSB fibers that were parallel to the long grain of the joist would have much impact on the strength you are looking for. So, the horizontal fibers would be good, but the vertical ones would do little. Since about 50% of the fibers run each way, OSB would contribute about half what the solid lumber would.
This also has to do with the "extreme" fiber. The fiber furthest from the centerline of the joist takes the most compression or tension. If you could make the new joists a 2 x 12 it would be significantly stronger.
And if you could get to the underside and cover it with OSB glued to the joists and screwed or nailed, that skin would add significant strength. This has the effect of turning it into a stressed skin panel.
PS...
SPF stands for Spruce/Pine/Fir (I think) and locally usually means one of the "white" woods used for framing. Speaking loosely here without researching every possibility Generally those woods have a Modulus of Elasticity of a 1,360,000 and Yellow pine has one near 1,760,000 meaning it is about a 1/4 stiffer. So, if you can make your repairs with yellow pine they will be stronger and stiffer than SPF.
The glueing/screwing/attaching the lumber to the original joist is also critical.
Clint Searl
Clint Searl
I framed my studio using 10" composite I-Beams for joists spanning 15' that carry a second floor living area. The I-Beams are common 1/2" OSB webs between flat 2 x 3's. Fully compliant with the IRC and praised by the inspector. The approach you suggest sounds more than adequate. Glued and screwed full depth webs will suffice. For belt and suspenders insurance go 3/4" or double 1/2" .
Clint
FredD
As Barry says the way OSB is formed only gives you about half of the value of a all horizontal fabrication.
So if you have your heart set on skinning the joist ,do yourself a favor and do it with Plywood , which is far stronger and well worth the added expense.
FredD
I would avoid construction adhesive...
John in NM
I've never had much luck with the stuff, seems to inevitably fail after a year or two. In most cases I would bet its not necessary, but if you have to use a glue, find one better than Liquid Nails.
Alex Grigoriev
In the webbed joist, the stretch load goes to one of those 2x3. The OSB web only experiences some compression. Plain OSB won't work for such load, it won't stand stretching load well.
