need veneering suggestion
Bill Tindall
Shown in the picture is a flitch of homemade veneer to be applied to a chest of drawers. The drawers start at 5 1/4" and end at a bit over 8" wide. The question involves how to trim the 9" wide veneer for a 5 " drawer. My instincts are to center the fairly symmetrical grain pattern on the center of each drawer, trimming to waste what ever hangs over.
Some veneered drawers have the veneer switched end for end on alternate drawers. I am inclined to not do this switching.
Opinions please.
Re: need veneering suggestion
Thomas S Stockton
Bill
On graduated drawers like that I either work from the center out like you want to or measure and cut from the bottom. So to decide which way to cut I usually lay everything out on my bench and start overlapping the veneers to mimic how they would look on the piece.
Looking at what you have I think the way you want to do it would look best. I have never cared for switching the veneers end for end it can distract from the visual flow. Also when the do the flipping isn't it usually done with crotches?
Tom
I agree with your proposed method
By centering the flat grain on each drawer front, you will be arranging the rift/quartered grain at the top and bottom edges of the drawer fronts, where they will complement each other nicely.
Re: I agree with your proposed method
Bill Tindall
I am going to mask off the drawer size on each proposed piece targeting getting the grain, variable as it is, centered. This is southern cherry and the grain is more dim than on N. cherry, so it is not as clear what is center as it might be. Hence, the trial and error masking.
laying out the veneer, per suggestions
Bill Tindall
This part took quite a while but it was time well spent. With sliced veneer each piece is nearly identical but with thicker sawed veneer the pattern changes from piece to piece. What looked best to my eye wasn't a consecutive ordering of the flitch but rather an order of pieces 3-2-4-5-1 (numbered as they were sawed). I tried book matching pairs of pieces and that looked interesting, bordering on strange. Reversing alternative pieces end for end looked more strange and was easy to reject.
Each piece seemed to have a "center of gravity" of the grain that was not necessarily in the center of the slice. I began by marking this center and measuring half the drawer width up and down from this point to establish what part of the veneer would be used for each drawer.
I am satisfied with the result of picking the areas for each drawer and its on to applying the veneer to the drawer fronts. Thanks to all that made helpful suggestions. Veneering is a new experience for me.
Re: laying out the veneer, per suggestions
Alex Grigoriev
Also make sure they are all oriented the same say regarding bark side/pith side, when you apply them.
Bill Tindall
That was my book matching experiment, but I preferred the way you suggested.
