Help finding a finish
mike defuoco
I am in the final stages of building a pencil post bed for my Granddaughter,
everything has gone well so far, but the real problem is going to be finishing it.
She wants it painted Satin Black to match the rest of her furniture
It is built out of Birch.
I would to use a wipe on Poly for the final coats
I was told that I could use a brush on lacquer but I have not been able to
find any with a satin finish.
I would also like to use a primer, at least for the posts
Any information would be greatly appreciated
Thanks
Mike De
Re: Help finding a finish
This is pretty low tech, but HD carries black lacquer in spray cans. Not sure if they have satin, but you can spray it with the black and then clear coat it with clear satin lacquer. Be careful to use lacquer over lacquer and even hen test first to be sure they are compatible. Birch should paint nicely, but it seems a shame.
confused.....
Bill Tindall
"she wants it painted satin black". So go to Sherwin Williams and order some satin black paint, or buy a spray can of satin black Krylon(or similar). How is wipe on poly, lacquer and primer involved?
Black milk paint
Re: Black milk paint
Doug Ridley
You'll have to find a black cow?
Re: confused.....
mike defuoco
Krylon makes good paint,I have used it but you can't put Poly
over the top of it,and I want a protective finish
not just paint.
Re: confused.....
John Veerkamp
Modern quality paints are just as durable as the poly. And will be easier to repair than if poly is over the paint.
Get a spray gun
Mike, the absolute best way to do this finish job is with a spray gun. Rattle cans are okay for small jobs, but this is a big one. I'd suggest satin black lacquer, which you can get at Sherwin Williams or other decent paint store. You can have several coats on in a day, with no further topcoats required. If you own a compressor of any size, you can be up and running for not a lot of money.
Anyhow, this is what I suggest.
Ellis Walentine, Host
flawed assumption
Bill Tindall
Paint can be just as durable as varnish, or more, or less depending, on the urethane formulation and the paint formulation. A quality oil enamel certainly holds up fine on architectural woodwork, or a porch floor for that matter.
But, if you insist on a varnish top coat than the suggestion of black milk paint followed by satin varnish is a good one. If you are not skilled at brushing (must be thinned to brush well) then the only alternative is learn to spray.
Milk paint with a overcoat of linseed oil is dull, durable and easily repaired. It was used for centuries on chairs.
Stephen Shepherd
Re: flawed assumption
Stephen Shepherd
'Milk paint with a overcoat of linseed oil is dull, durable and easily repaired. It was used for centuries on chairs. '
That is the flawed assumption. Milk paint is a myth, the earliest it is mention in literature is the 1960's, now buttermilk paint is first mention in literature much earlier in the 1930's.
Just because people would like to think it existed doesn't make it real. There is no historic record, no inventories, no advertisements, no history, for milk paint. If it contained milk it was Whitewash and that is used for walls and ceilings and not on furniture.
Stephen
Clint Searl
There's disagreement here
Clint Searl
This is from, http://www.milkpaint.com/about_history.html: "Paint has been used by mankind since before recorded history, first as decoration, and much later as a protective coating. The oldest painted surfaces on earth were colored with a form of milk paint. Cave drawings and paintings made 8,000 years ago, even as old as 20,000 years ago, were made with a simple composition of milk, lime, and earth pigments. When King Tutankhamen's tomb was opened in 1924, artifacts including models of boats, people, and furniture found inside the burial chamber had been painted with milk paint.
Because the original formula for milk paint was so simple to make and use, it was for thousands of years a major form of decoration throughout the world. Over time, and in various places, different recipes, including milk protein(casein), lime, and pigments were tried, producing varying results in durability. Many of these coatings also provided weatherproofing, while others disintegrated, leaving only a permanent stain on the painted surface. The variations included adding substances such as olive oil, linseed oil, eggs, animal glue, or waxes. Over the centuries, better recipes were found that could produce a durable coating, which could last indefinitely. The colors on the walls painted at Dendaras, even though exposed to the open air for centuries, are as vivid today as they must have been 2000 years ago."
Who's correct?
Clint
Stephen Shepherd
Re: There's disagreement here
Stephen Shepherd
I am.
The cave paintings were bound with hide glue as a binder and earth pigments for the color.
Distemper painting is the type that was done on Egyptian work which is a binder like hide glue size, egg glair or a vegetable starch with pigments added. They also had a protective coat applied over the top. Distemper painting of furniture in the 17th century are documented but it is not milk paint.
Stephen
Clint Searl
Clint Searl
I think it stretches credulity to accept the assertion that milk paint is a historically recent invention. As a product abundantly available for thousands of years, it's inconceivable that milk in some form wasn't added to lime, chalk, pigments, and other naturally occurring earths to make or modify a sort of paint. Whether whitewash (lime and chalk) predates or excludes milkpaint (milk solids and lime) is a quibble not worth pursuing.
BTW, my research turns up no mention of hide glue being used as a pigment binder in cave paintings 17,000 - 30,000 years ago.
Clint
Mark
Or....if you could find say 50 cows of all colours and mix the milk you would get to black
Re: Get a spray gun
mike defuoco
Thank god for guys like Ellis Walentine
When you need help
