Forstner bit sharpening
Gary Smyth
Anyone know of a place where Forstner bits can be sharpened? I haven't a clue as to how I might do it myself.
Re: Forstner bit sharpening
Its pretty easy...
John in NM
I sharpen them myself, just use a triangular file or small flat file for the cutting edges, following the bevel that's already there, and then a dremel and small cone stone to touch up the rim. The relief cuts in the rim let you get the right angle on the bevels with the file, you can either count passes or mark them with a sharpie if you're not confident over keeping them even. As long as the rim stays pretty uniform and slightly proud of the cutting edges, it should cut fine.
Of course I've had the best luck sharpening high quality forstners. I have one Chinese one that doesn't cut straight on a deep hole. I suspect something is funny about the grind, but I've never stopped to figure it out - probably just toss it and buy a good one instead next time I need that size (not one I use often, hence the temptation to buy a cheepie).
Re: Forstner bit sharpening *LINK*
Dave Peebles Lyons, Ohio
Hi Gary,
In addition to what John posted, here is a little more info from Lee Valley on sharpening the forstner bits.
Dave
Lee Valley
