jointer head RPM?
jointer head RPM?
jointer head RPM?
Carol Reed
What is the optimum RPM for the jointer?
Re: jointer head RPM?
Galen Vetterick
Carol
I thought you said you got the manual to the jointer. I would keep in line what it gives based on what bearing it has and the mass of the head. Probably about 12,000 cuts per minute on older unit. With a 3450 rpm motor and 2 1/2" pulley on the motor and 2" on the head that would be 4312 rpm and if a three knife head that gives 12937 CPM based on no load speed.
Look at your parts list for pulleys they list and see what you get.
Even if you put a bigger HP motor on I would not push bearing speed unless you know they can take it for long. It's only like 1/2 or 3/4 HP as I remember.
Carol Reed
Doh! I didn't look in the book. I replaced the motor set-up. There were two joined with a rubber water hose shaft to shaft with a 5" pulley!. No kidding!
I had a 3450 motor and used it with the pulleys that were on it. They are not right. You were right, Galen. I had a 2" but not a 2 1/2". Will get one tomorrow. Really wound up with the honkin' big pulley, though!
I installed the newly sharpened knives. Didn't take all that long. Can't say the guy did a super job sharpening. He didn't, but in this case, something was better than nothing. At that super speed, the cut is as smooth as glass. We'll see how it goes with the right pulley set-up.
Gotta get a guard, though, that is scary without one.
Kneale Brownson
Kneale Brownson
Even with the guard, you always want to use push blocks.
