1975 Craftsman jointer
Carol Reed
I 'inherited' this gem from a local widow. Heavy cast iron monster. Only 6" but more than adequate for my purposes. I liberated the knives yesterday. Took some doing, too! They weren't fit for spreading butter but a local sharpener took care of that. No time to send them to Scott. Next time.
General clean-up and straightened out some wiring issues. One day it will go on its own wheeled cart with a decent motor and shavings collection system. A little rust removal on the infeed table needed, but not bad. All in all, a fairly good tool that served without any real maintenance, worthy of a second chance. Even got the book. And the price was more than right! Good to be known as a local woodworker, in addition to pastor. The members keep me blessed.
I Googled for a replacement pork chop guard as that is missing. No longer available. Anybody ever make something like this - or have one laying around?
Also, Sears wants $38 for replacement knives. Reasonable? Other places to look?
Re: 1975 Craftsman jointer
Joe Bradshaw
Joe Bradshaw
Carol, shoot me a pm with your address. I think that I have one or two sets of knives for this jointer and also maybe a guard.
Joe
Carol Reed
carol.j.reed@gmail.com
model # is 113.20680.
Thanks, Joe.
Jim DeLaney, Austintown, Ohio
Carol, I made a pork chop for my old Delta. I used plain ole 4/4 poplar for mine, and used a piece of (I think) half inch steel rod, with a lengthwise slot cut in the bottom to accept the tensioning spring, and pinned in place to the pork chop. It only took about half an hour to make. Also, I glued a small knob to the top of it so it's easier to retract without any chance of fingers meeting knives (even when the jointer is off!).
Carol Reed
That's good info, especially about the slot to grab the spring. I wondered about that. Thanks, Jim.
del schisler
I used to have that jointer. The knives are a job changing and get set right Good luck with it
Dick Coers
Is that the machine with a fixed outfeed table? They are a bit@# to get set right. You may look into some type of magnetic setting aid because getting them parallel and just a few thou above that table is really tough. I was really glad to to get rid of mine. Probably did that sometime around 1976! LOL.
Carol Reed
Funny. I had no problem. I do have the magnetic thingy but forgot how to use it. Went back to the old steel ruler and trial and error. Took a little less than an hour, but then I haven't done this in a while. Th trial cut looked good, but I think that has to do with the excess speed. See other thread.
Doug Turner
I made a blade guard from a piece of 3/4" plywood and a bolt for the shaft. A thread nut allowed attaching the plywood to the bolt and a hacksaw cut in the bottom of the bolt for the spring did the trick. You can adjust the tension by loosing the nut and turning the plywood and then retighting.
