ADVERTISE HERE - FREE TRIAL
Stains in Maple
Stains in Maple
Stains in Maple
Joe in a Cleveland suburb
Hello.
I have some figured maple I wanted to use for an upcoming project.
While laying out cuts, I noticed some of it has small blotches. I guess these blotches are stains. I used a hand plane to see how deep they go. The hand plane didn't remove them. So I don't know how deep these stains go.
The picture doesn't show it very well, but they look like they have a dark green'ish color to them. All the stains are about 1/4" to 3/8" across.
Any ideas what might remove this? Bleach?
Suggestions? Firewood?
Thank you.
Re: Stains in Maple
Re: Stains in Maple
Bill Tindall
probably mold stain. Fresh cut Maple molds easily in warm weather. Chlorine bleach will render colorless mold stain. Don't know what it will do to the natural wood color.
Bleach is strongly basic(caustic). So I would guess that this stuff would have to be washed off afterward before a finish is applied.
Might try peroxide first. It has the advantage of being completely volatile, but I don't know if it will bleach mold stain. It works more aggressively if basic so you might add some ammonia to the wood and then add the peroxide.
This stain might just belend away if you intend to stain the maple.
Re: Stains in Maple
Re: Stains in Maple
Thanks for the reply Bill.
I do plan on using Trans Tint Early American Maple on it. But I think the stains would still show through it.
Joe
Re: Stains in Maple
Re: Stains in Maple
del schisler
If you dont use a blotch control on the maple it will blotch real bad. watch the video of charles neil on blotch control . The box store's stuff doesn't work that well but this will
http://www.youtube.com/profile?user=InTheWorkshop#p/u/34/IfCYMdrP8rM
Re: Stains in Maple
Re: Stains in Maple
Thanks del but what I am dealing with isn't what is in that video. He's talking about blotching from finishing. My wood has nothing on it. I think, like Bill T says, it's a mold or something.
I am wondering if that (mold, fungus, or whatever it is) can be removed.
Thanks.
Re: Stains in Maple
Re: Stains in Maple
Yonak
It seems like it would be worth a try to treat it with chemicals. If you can spare a bit to test on, you could try dabbling bleach and/or peroxide on some spots and see what happens. It may work better, or worse, if you let it work in the sun. I would wet the surface with water first to wick the bleach some so you don't leave a line. Be sure to let it dry after rinsing off then finish completely to be sure any residual chemical doesn't leach through.
Re: Stains in Maple
Re: Stains in Maple
Howard Acheson
There are three bleaches typically used on wood.
** Chlorine bleach (Clorox) -- used to remove dye stain coloring from wood. Does not materially affect the color the wood.
** Oxalic Acid -- used to remove mineral stains from wood like rust or black color from tannin and metals.
** Two part A/B bleach -- use to remove the natural color from wood.
In this case, I would try the oxalic acid. You can get it at most real paint stores. It is sometimes marketed as "wood bleach". Mold is difficult to deal with and you may have to use the board for a painted project.
Re: Stains in Maple
Moses Yoder
Re: Stains in Maple
Moses Yoder
If it were mine, I would leave it as is and consider it beautiful. Once the wood actually changes color, if you bleach it or otherwise chemically change the color of the wood you will also change the surrounding color, most likely leave a piece that looks worse than what you started with. One way to get rid of the stain is to seal the piece, then mix paint to match the surrounding wood color and paint over the discolored piece, then add in graining. In my opinion this is wasted time. The discoloration does not affect the function of the piece in the slightest, and the little discoloration actually adds visual interest to the piece, drawing in the observer.
Re: Stains in Maple
Re: I agree with Moses
I would not consider it a problem at all. In fact I like to use wood with visual attributes like stains - small knots etc. unless it is a very formal piece. Even with a very formal piece I would not consider the stains you show in the picture to be an issue. If I wanted to have a uniform looking item I would make it from particle board and paint it.
Re: Stains in Maple
I also agree.  Leave 'em.
