We value your privacy.
I saw this on another (non-woodworking) forum. I guess it's not really a joint, but a way of bending wood across the grain. It was used, apparently, by Haida and Kwakiutl native americans in making the corners of boxes and chests. The depth of the cut would appear to be equal to one radius, as would the width of the cut at the surface. The width of the cut at the bottom would, I think, have to be the radius of the circle. (Say you were bending a 3/4" board, and leaving 1/4" to bend. The depth of the cut, and the width at the top would be 1/2", and the width of the cut at the bottom would be 1 inch, or slightly larger for bend allowance). I don't believe the joint could be cut with a rotary tool, and I'm pretty sure the native americans didn't have routers available. I'm thinking of perhaps a kind of a curved dovetail plane blade. What do you think?
That is a bit later style of 'kerf' boxes made in the Pacific Northwest by the local Native Americans, this one is called a 'Boaz kerf'. It is done with a straight knife and a crook knife. The wood alder, western red cedar was worked green, and the 'joint' is cut cross grain. The 'joint' where the kerf is located, is wet with water and the outside was pressed against hot stones to vaporize the water, steam the wood and allow it to bend.
The earlier style is a simple V cut made cross grain and bent using the above method.
There is a how-to article in one of the early Fine Woodworkings on these boxes. I don't remember which one but I believe it was before they went to colour.
videos on "You Tube" showing some methods, (look at "Carved cedar box" and you can go from there. I looked to get a link, but none I can find showing how to cut the joint. Roy Underhill did a show from the Northwest some time ago that showed a person cutting the joint. He used what he called a crooked (crook?) knife to get the undercut. If I remember correctly it was a two handed knife. They come in left and right hand versions. The demonstrator made the knives as I recall, and Roy bought one or more. A company named "Hirsch Werkzeuge" makes a one handed "carver's hook" that is similar.
