Double tenon question?
I want to attach some legs to some stretchers. The legs are ~1 5/8" x 1 3/4" or so. I was going to make the stretchers ~1 5/8" x 1 3/4" also. I was considering using double tenons for this application. I figure double tenons would be more secure, etc., etc.
Question - if I decide to use double tenons I was thinking of making them ~1 1/4" x 3/8". This would make my mortises the same size. If I do this, the amount of wood on the outside would be ~3/8" on the "sides" and 1/4" on the top and bottom. The amount of wood between the two mortises would be on the order of 3/8" or less. Is this enough?
Should I make the mortises and tenons less thick? Make them say 5/16" or 1/4" instead?
