pre catylized lacquer
Ed Pretty
I recently found that Mohawk has waterborne precatylized lacquer. I would like to try it but am reluctant to shell out for a gallon without any prior knowledge. I have been quite pleased with other waterborne finishes developed in recent years and hoped that this would be the same.
Has anyone use that or similar? I am curious about its finished appearance and anything that may be of note.
Re: pre catylized lacquer
Clint Searl
Clint Searl
To each his own, but I have to wonder what actual need a catylized finish serves in the home/small workshop setting. It seems to me that regular film finishes offer enough alternatives to meet most any normal household situation.
Clint
Dick Coers
I was never a fan of solvent based precat, after using a bunch of it. It didn't meet the claims of water and heat resistance, and was really touchy with film thickness. Too thick and crazing was a big deal. Sorry, no advice for water base, except watch the date on the can. Precat has a shelf life.
Ed Pretty
Thanks, Dick. I understand what you're saying about solvent base. That's a start
FredD
Well Ed ,I have the opposite experience with Pre-Cat Lacquer. if you follow directions and manufacturers recommendations , like using a Vinyl sanding sealer first , you shouldn't have any problems spraying Pre-Cat Lacquer or any other solvent based Lacquer.
On the other hand I wouldn't touch a water based anything with a ten foot pole.
People who repeatedly who lay down heavy coats of finish often have cracking and crazing issues .
FredD
