Staining and finishing advice needed.
They got a new double door at the playhouse. Nice door. Really solid.
The only "problem" is that the "ledge" separating the two parts is a softwood like spruce. The door skin is probably birch. The spruce is nice and white. The birch is somewhat darker.
I'd like to stain it or dye it to unify the color and then cover it with something suitable. The old doors have an "aged varnish" sort of look to them. A bit of a PITA to match.
My first thought was to use a "conditioner" and then use a couple of coats of a suitable stain (probably Minwax). Put on a couple of coats of polyurethane and be done with it.
My next thought was to use something like a waterborne polyurethane or Polycrylic which have a lot less odor and solvents.
I then though about using a dye (Transtint) and getting a reasonable color match to the older doors and then using the waterborne finish.
Thoughts?
