Harvesting a Maple Tree
Alan Young
Alan Young
We have a 13 ft long 24"-30" in diamter Maple tree that came down a week ago. Due to logistics I may not be able to get it cut/ sliced into lumber for drying before next spring. should I paint the ends to protecit over the winter? Will that help at all? Can't post pictures as I am on a remote and unfamiliar login....I'd appreciate and advice....Alan
Re: Harvesting a Maple Tree
Bob Hackett
Get it up off the ground and by all means seal the ends. I use Anchorseal but anything is better than nothing.
Keep it out of direct sunlight and maybe throw something like a piece of tin roof on top of it to keep the rain off. Don`t just throw a tarp over it and weight the tarp to the ground unless you want spalted lumber. If it`s hard (sugar) Maple you want to saw it up as quickly as possible,leave it set and it`ll dry out and check before next spring.
Bill Tindall
Certainly would not hurt to paint ends but it would be better to leave the log 6" longer than its ultimate fate and trim just before sawing. More important is the desirability of getting it cut and drying while it is cool. Fall is an ideal time to get lumber up on sticks (which must be dry to prevent staining. I don't know where you live but in many climates it is starting to be cool such that the lumber will dry slowly and the sun is lower where the lumber won't get baked at mid day.
It is critical to get the surface of maple quickly dry after cutting or there is the certainty of mold if the weather is warm to hot.
I give it the Snow Ball's chance,
Keith Newton----Little Rock, Arkansas
around here anyway. The decay and insects will make for some pretty ugly lumber. You might try sinking it in a pond though.
Ed Pretty
I agree with Bob. Get it well off the ground and cover with something that sheds rain/snow but still allows good air movement. If you don't have end seal or can't get it, I recently stumbled on a reasonable alternative. Some folks had some arbutus/madrone and commissioned me to turn something from it. was unable to get to them or vice-versa for several months. They had no wood experience at all. I suggested a good layer of spray-on foundation sealer or automotive undercoating on the ends and to cover it as suggested. I picked it up a couple of weeks ago and it was just fine.
Bob Hackett
Liquid Nails or thick yellow glue works as an emergency sealer too.
Whenever I work with asphalt sealer or roofing tar I end up looking like Al Jolson. :^(
Alan Young
Alan Young
The Tree is in Michigan's Upper Peninsula. I live in the Lower Peninsula and only have til Octber to deal with this if that late at all..Thanks for the information...
Bill Tindall
It would not be unusual for a log to sit on a log yard several months waiting to be sawed. In 3 months your log will be frozen and in suspended animation till spring. You could get it up off the ground and onto a couple of limbs but beyond that nothing additional is called for in that climate. Just so it would be drying ever so slowly in the winter(desirable) I would try hard to get it sawed , on sticks and covered this fall. It won't be ready to work in the spring, but it will be well on the way. Just keep the pile covered. Something about snow melting on lumber makes the lumber more soggy than just rain.
Dick Coers
The way this summer is going, the heat is going to hang on quite a while I would say. You may get some lumber next year, but the degrade will be pretty high. If it is soft maple, even worse. Lots of bugs love to get under the bark, and they will have there way for a few more months. After the bugs get in, they will lay eggs and those will be in a little deeper, and will be in there when you cut.
