Process Question
Process Question
Process Question
Todd Nebel
I'm starting a new project, a table that has turned legs in the Shaker style. The upper 7 inches of the leg will remain square. The rest will have a turned shoulder, a single bead and a straight taper to the bottom. My question is do I turn the leg on the lathe first and then cut the mortises for the side rails and the dovetail grooves for the bottom drawer rails and the seated dovetail for the top drawer support or vise versa? The DTs that will be cut in the top of the legs will interfere with holding the leg on the lathe unless there's a trick.
Thanks, Todd
Re: Process Question
My preference is to make the leg a bit long (couple of inches). I cut the mortises and measure where the ends should be. I then turn the legs. That way nothing is really interfering with my mortises. I then trim the leg to length at the top. I usually level the table and sometimes trim a little off of the bottom after assembly.
Joseph Mulherin
JL has it right...measure the legs a little long, cut the mortises after running them thru the planer to make sure they are exactly square. It is easier on the mortising machine to have the full stock to keep it stable while doing the mortises. Go to Norm's New Yankee website this week and he has a demo on turning legs which I think you will find most informative.
Todd Nebel
Hi Joseph,
The video has Norm turning the leg first and then cutting the mortises. But, I agree it's easier to cut the mortises first. So, since I'm less sure about my turnng skill than my mortising skill I will cut the grooved DTs in the leg for the drawer's lower rail, turn the leg, cut the leg to final length, cut the side rail mortises, and finish with cutting the DTs on the drawer's top rails. I'll take photos if interested.
Thanks Todd.
