Found it in the wood pile
Bill Tindall
I have underway a 3/4 scale chest of drawers for granddaughter. I wanted something special for the top two drawers. Found it in the wood pile.
A large cherry had blown down last year. When I split the lower part I noted it was curly so I set it aside and never burned it last winter. It took quite some effort to get one side of the split piece flat and then it was easier to get another flat and then I was able to slice some veneer which will look fine on the top two small drawers.
Re: Found it in the wood pile
Pretty fancy wood pile, Bill!
Bruce, a MN Galoot
Mind if I go through it some time? :D
That'll be a very special dresser for the young lady.
you may stack it any time...or.....
Bill Tindall
split it to see what is inside.
Sliding dovetail questions
Nathan
Nice chest of drawers, Bill. I have questions regarding the sliding dovetails. Are they tapered or straight? Hand-tools or by machine? The dovetail in the frame underlaying the two top drawers appears to have been done after the frame was assembled - correct?
Re: Sliding dovetail questions *LINK*
Bill Tindall
I described the making of a dovetailed case in a post on the Hand Tool Forum July 31/2011. If I executed the arcane mumbo jumbo for citing this post a link to it will appear in this post.
I don't understand the rest of your question. There is no frame involved and all the dovetailed parts are assembled at one time using liquid hide glue (which has a long working time and it lubricates the joint while assembling).
I'll make a guess....you think the drawers sit on a frame.?. Not the case. The drawer dividers/blades are dovetailed into the case sides. The drawer runners (that part the runs perpendicular to the case front) are loosely tongue and grooved into the dividers. They just float there so as to not constrain the movement of the sides. If you can pull it off I like to have them raised just a few thousandths of an inch above the drawer dividers. They are made of slick wear resistant maple and waxed. The result is a drawer that works smooth as silk.
If not clear ask again.....
http://www.woodcentral.com/woodworking/forum/handtools.pl?pro=search;pmd=sread;srchid=25202tyOVtsK9WBctQMK1314534041;spage=2;sanc=156747;sbid=3000;md=read;id=156747#m_156747
