Restoration Help
Restoration Help
Restoration Help
Clementine
A fellow church member gave me a 6' pew made of oak that's maybe 80-100 years old. It was dismantled and stored years ago. It has a dark oak finish, but is covered in dirt and grime. I want to begin by cleaning it so I can tell something about the finish. But the advice for cleaning it is all over the map (Use Murphy Soap - Never use Murphy Soap, etc.). I have about decided to start with an 8-1 water and vinegar solution. This is my first restoration, so I'm looking for help. I don't want one thing to mess up something later. Can anyone (Please!) help?
Re: Restoration Help
Stephen Shepherd
Stephen Shepherd
Clementine,
Washing a piece initially is a good idea, use soap, not detergent and distilled water. This will wash off all water soluble stuff on the surface, oil, grease, dirt and grime. The distilled water and vinegar will work as well. Make sure you dry the surfaces completely after washing.
Send me an email and I will send you a small bottle of a product I make [Moses T's Reviver], that will take care of the pew after it is clean.
Stephen
Clint Searl
Clint Searl
It's oak, it ain't gonna melt. Make a 10:1 solution of water and ZEP Tub and Tile cleaner. Wet it down and use the solution with a soft bristle scrub brush and maroon ScotchBrite to loosen and disolve the grime. Hose it down well and towel it off. Let it dry completely. and strip with a citrus stripper if you want to refinish.
Clint
Bill Tindall
I can't think of anything useful that less than 1% acetic acid will do to clean anything. Personally I remove grime with wax and 4/0 steel wool. The wax will have a strong solvent as part of the formulation and this solvent plus the wax will dissolve grease and the like. If the finish is thin/worn then steel wool and linseed is used.
Al Stokka - Cambridge, Iowa
Clementine,
A recipe from, now passed, Sam Simpson, a professional who used to grace Wood Central with his wisdom, posted Saturday, 18 March 2006, at 4:39 p.m.:
American
8 fl oz Pure turpentine
4 fl oz Denatured alcohol
2 fl oz White vinegar
1 fl oz Murphey's Oil Soap
1 fl oz Brasso
1 tspn houshold Ammonia
Al
Don Orr
If that came from Sam it has to be good. Haven't seen that name in a long time. Sure miss his input.
I'm sure the other "solutions" will work as well.
Good luck and feel free to show pictures.
Howard Norman
Al, I have used the cleaning formula from Sam several times and have always been pleased with the results.
