We value your privacy.
Alright I'm going to open myself up and show how stupid I am and ask what is the difference between the Daiblo by Frued and just Frued??? I'm sure I'm getting laughed at here but whats up there? Home Depot sells this brand and I'm just wondering if there is a difference here?
$50 for an 80 tooth Freud Diablo (10") versus $80 for an 80 tooth Freud LU85R010.
Call it "builder grade" versus "cabinet grade". Which do you want on your table saw? Your choice. I've got the LU84R011 50 tooth combination blade ($70) on my cabinet saw. I like Freud. I'd buy the Diablo for my compound miter saw or my 7 1/4" circular saw - but not my cabinet saw.
I buy the "Freud industrial" line blades on recommendation from one of their reps. As a woodworker, I can't see the benefit of using the blades with the non-stick coating, as my saw is properly tuned, and I tend to only rip straight lumber. The non-stick would be just the ticket if I often ripped twisted stuff or other operations where the wood contacted the "non-tooth" area of the blade.
If I were a contractor sawing construction materials with all the pitch and crooked boards, I could justify the extra money for the fancy red non-stick coating.
I was given a new Diablo 10" blade. The blade was actually 10 1/8" and would not drop below the table surface. had to remove it every time I needed to move the ripfence to the other side of the blade. Also the blade distorted and flexed and had a very poor quality cut. I tossed the blade, my opinion JUNK.
Here is Freud's answer to that question from a few years ago. AFAIK, Freud no longer makes the "TK" line of blades.
All Freud blades come from the same machines in the same manufacturing plant. We make our own micrograin carbide in numerous formulations that represent various degrees of hardness. The carbide is selected depending on the intended application (the hardest is used for laminates the softest for ripping) as are the tooth angles and tooth quantity. The steel for the blade plates is all the same grade. The brazing is all the same. The key differences between the 3 main lines of Freud blades are:
The LU/LM Industrial blades have the thickest tips for the most resharpenings and are generally full kerf. We also offer the most selection of specialty blades in this line. These have the most appeal to professionals who need to get a lot of sharpenings out of a blade and to artisans who need specialty blades for their projects.
The TK and Diablo lines are very similar. Both are thin kerf blades and the tip thickness is the same. The key difference is in the way we market these blades. The Diablo line has blades intended for purposes like framing, siding, decking and general home improvement and is packaged and promoted in ways that appeal to contractors and DIYers. The TK line has blades for similar purposes (as well as laminate blades) but is sold with different or no coating and different packaging and POP material to appeal more to woodworkers.
Do professional woodworkers shop for blades at Home Depot? Probably some do and they can get excellent performance from a Diablo blade for a lot of their uses but with a shorter overall life (and lower cost) due to the tip thickness. Same with the TK blades at Lowe's.
Why not compare a TK or Diablo blade to Forrest? Consider this analogy: Toyota cars and Lexus cars share a lot of the same components and are made by the same company. Would you compare a Camry with a BMW?
We make a fourth line of blades (F400 Premier series) that is very similar to the WWII and is priced similarly. The difference between ours and Forrest's is that ours is made by computer controlled, super modern equipment and theirs is made by hand. Both methods have advantages and disadvantages but I leave the final verdict to the consumer.
