LACQUER FINISH
LACQUER FINISH
LACQUER FINISH
JERRY DRAPER
Can I apply Deft Lacquer spray from a can over Danish Oil?
Re: LACQUER FINISH
Yeah, But . . .
Deft (and most all the rattle can stuff) is pretty low on solids meaning you're going to be applying a lot of thin coats to get any kind of build.
What's the item?
Re: LACQUER FINISH
Re: LACQUER FINISH
FredD
Yes , but the instructions on most Danish finish say let dry fro 72 hours prior to the finish application.
If the item is small, Deft in the spray can works fine , less mess then a gun application and you can do four to five coats in less then a day which should be enough.
Do two coats and finely sand , then two or three more without sanding, makes a nice finish
FredD
Re: LACQUER FINISH
Re: LACQUER FINISH
JERRY DRAPER
Item is a small Bracelet Box & I was concerned about adhesion. Thanks to both of you for your advise.
Re: LACQUER FINISH
Just For Laughs
and giggles, you might consider dulling the surface with 600 or above (or 00 or 000 steel wool) so that your lacquer has a less-than-glossy surface to grab. If you wool it, either use oil-free wool or wipe it with a little naphtha to remove the very light oil used to keep steel wool from rusting in the bags.
Re: LACQUER FINISH
Re: Yeah, But . . .
Phil Joines
Krylon in the can is much higher in solids.
