We value your privacy.
A friend of mine has a piece of white pine recently cut that is 24" diameter and approximately 4" thick. It still has the bark on it. He lives in south Fl. He asked how to keep t from splitting so he can make a table top of it. I suggested coating it with anchorseal and or wrapping it in newspaper and forgetting about it for quite a sometime. Any better ideas? I said that it could take a few years under this process. (?)
Start by sealing the end grain very will. Hot paraffin does well, but several thick coats of latex paint will do.
Next pick a reference surface (floor) that is flat. Make some 3/4x3/4x24" stickers, place them not more than 18" apart across its width to support the plank for its whole length.
Put the plank down on the stickers. Apply weights on top of the plank; I use 4" solid concrete blocks. For a 24" wide plank, I'd use at least two blocks every 2 feet of length. More weight is better to keep things flat.
Every 3 months or so, move the stickers and the weights, then check with a meter every 3 months until no change or it meets the same MC as the framing lumber of the residence.
Hopefully he cut it oversized. Anchorseal or similar products work reasonably well. Hopefully, the piece does not include the pith of the log (the very center).
I've used newspaper to slow the drying of bowls, and it does work well. One of the methods of slow drying bowls involves wrapping the roughed out bowl in newspaper and putting it in a paper bag. That being said, you really want a bit of air circulation about the slab - or it will take FOREVER to dry.
Another thought, rinse down the outside of the slab with a solution of bleach and water. This will kill (or at least knock down) a lot of the mold, fungi and bacteria.
I've air dried 3" thick slabs - those took about 2 years. The ends were sealed and they were put in the attic space of the garage. They were "stickered" by spacers that I put on the trusses.
It sounds like you are talking about a circle slice cut across the trunk showing the pith and growth rings I don't think he is going to get it dried without cracks. Instead he might want to use the prior posts and cover it with Anchorseal, keep it in the shade and forget about it. Once it's dried in a couple years use epoxy colored to whatever looks good to celebrate the cracks not hide them. It might take a bunch of CA glue to hold the bark.
I think he would have better luck moving Mt. Everest into the Atlantic ocean. You could do that with just a wheelbarrow, a pickaxe, and a shovel. Keeping a tree from shrinking more on the outside of the tree than it does on the inside, well that's a whole different story. You might get some PEG and mix the stuff up and submerge the slice of tree into it, but it will probably crack before you can get the tub ready.
This is something that I've read about on WoodCentral but I've never tried. The technique sure does make sense to me. After seeing LOTS of wood rounds, firewood chunks, whole tree trunks and PILES of branches dry and crack it seems valid.
Make a cut above and below the one that you want for the table. Even more if you want to have some extra insurance.
Use a bandsaw to make a slice from bark to pith. This is a stress reliever. On the slabs above and below the keeper make the radial slice on another spot.
Seal the surfaces.
Place the slabs inside plastic bags to slow the drying down. Open the bags once in a while to vent.
When you figure that the slabs are dry the fun will start.
The slice will likely have opened into a pie shape. Use this as a pattern to cut a slice of woodpie from one of the adjoining slabs. Match up the grain and glue the pie piece in. With some careful fitting I've read that the cut lines are almost invisible.
It's gonna split, so get it over with. Leave it bare, but under cover with good air circulation till it finds its final state, Then incorporate the split(s) into the design, or make kindling. I think it's too thick to begin with.
Sounds like everyone has said what I was thinking, but trying to be kind and not say. I normally do bowls and have learned not to do what has been done in this situation. This was my first experience asking for advice like this. WOW! What a great resource. Thanks to all
Is this a "baloney" slice rather than a long plank? If so, tell your friend to just let it sit and see what happens. It will split to the center, only question will be how many cracks will it take to relieve the drying stress.
pine you aren't going to set the pitch in air drying . I belive it will come out in the wood. I know you have seen this at some of the box store's . It look's like gum. I belive kiln drid to set the pitch has to be around 160 degree's . Maybe a little lower temp. pine would be my last wood to work with to much pitch for me even when kiln dryed . my 2 cent's
It will take a few months at Florida temperatures. Softwoods yield their moisture readily. "2 inch" framing lumber is dried in two days. I had a piece of 2" spruce cut for making paddles and it was nearly dry by the time I got back home from vacation. If it doesn't have the center of the tree in it it will dry fine. If it does, it will split no matter what is done.
One trick the ship builders used, at one time, on the masts was to drill (burn) a hole in the center of the log, 4-5 feet deep. This reduced the stress and alowed drying to occure from the center as well as the outside of the log and reduced checking. The end was cut off when the mast was turned/finished. The cut ends were often used to carve cigar store indians. It is not uncommon to find one that has been pluged at both ends and at time left unpluged.
Thick square sections of wood are quite commonly bored out (25- 30 mm)down the middle prior to drying, but the hole isn't really there to let moisture out-- there's generally not enough air movement to significantly dry the wood inside the bored hole. The hole is primarily there to provide somewhere for the wood to shrink in to as it dries which reduces the chance of radial shakes develeoping. Slainte.
The rate of moisture transport out the end grain is 10X that across the grain. If this is indeed a baloney slice, that was unclear to me, this thing is going to be dry in days not months if it has good air circulation and typical outdoor FL summer temperatures.
