Peeling Paint
Peeling Paint
Moses Yoder
Peeling Paint
Moses Yoder
Attached is a picture of a customer's door who bought a kitchen from a competitor about 1-1/2 years ago. The doors are a mitered frame and panel construction, which you see in the bottom right corner. The paint is peeling in all the corners of the doors. We quoted about $6000 to replace the doors and drawer fronts in a medium sized kitchen, which the customer I think is planning on taking to small claims court. The manufacturer refused to repair or replace the doors. We have had some issues like this with vinyl paint in areas around the sink where it was subjected to moisture, but have never had this problem over a widespread area on all the doors. Whenever we have had problems, it has been with vinyl paint. I am wondering if this was vinyl paint and improperly applied, or why do you think the paint would peel like this?
Re: Peeling Paint
Speaking Evidence-wise
Your firm or your client would do well to take a sample door to a lab and have the peeling area(s) tested for presence of a "foreign" compound that interfered with the coating adhesion. Noting the poor miter joint (open on the inside), I wouldn't be too surprised to find joint filler that was slopped on without consideration as to the effect on the paint.
Re: Peeling Paint
Stephen Shepherd
Re: Peeling Paint
Stephen Shepherd
The problem as I see it is that is vinyl paint. Properly applied oil based paint doesn't have this kind of problem, resists water, and it has a proven history.
Stephen
Re: Peeling Paint
Clint Searl
Re: Peeling Paint
Clint Searl
Must be because they didn't start with BLO to "pop" the grain followed by a spit coat of shellac.....or maybe the other way around. Nyuk, nyuk
Clint
Re: Peeling Paint
Stephen Shepherd
Re: Peeling Paint
Stephen Shepherd
Clint,
Actually an initial treatment of the finished raw wood with linseed oil/turpentine 50/50 would give it a good prime for the oil paint to adhere. And shellac can be used to size knots [thin hide glue works too]. This would follow the old tradition of 'fat oil over lean oil'.
Stephen
Re: Peeling Paint
Re: Peeling Paint
JMOHNIKE
What happens when you sand the exposed area. Do you get wood dust, or glue dust? Someone may have been sloppy with the glue when the door was made, and wiped the glue off with a damp rag, but left enough so that the paint would not stick to the wood. I have seen this happen many times, especialy with latex/vynal paint. The method I use to find out is to remove some of the paint where it has bonded to the wood and sand only that are with 500 grit. Then I wipe down with thinner or water. If there is glue on the wood there will be a color difference. I will sand the area, and keep testing with thinner until I get the same color. The glue should be gone and ok to re-paint.
Re: Peeling Paint
Re: Peeling Paint
Dick Coers
Lacquer will do this, and I think precat lacquer will too. It usually starts when the wood moves and the lacquer cracks. Then moisture gets in the crack and it gets as bad as a an 80's Chevy pickup in the rust belt. Paint falls off. It appears to be hard maple, and if sanded too fine, it can make it worse for the paint to grab the wood too.
