Re: OT - Computer purchase
Bill Howatt
I run 32 bit Windows 7 or XP which means my 4GB machine can only use about 3.5GB RAM and my other machines all have under 3 GB in them. My use is similar to yours other than a music editing program and RAM availability is not a problem. The people who typically need huge amounts of RAM are gamers and Photoshop users who are manipulating large images. However, RAM is very cheap these days so they can load a machine up for little extra cost. You will need the 64 bit version of Windows to access all the RAM being offered in either case. This can be a problem if you want to use some older hardware because there may not be a 64-bit driver.
Right now my best machine is a first generation 2 Core-duo machine which is inferior to even your cheapest option and its performance is more than adequate with W7 and running your applications listed.
The video "card" being offered is likely on-board video which is not the fastest and performance can be upgraded with a better quality separate card. This card will have its own, often faster, memory and will not poach system memory. A better video card add on could bump the price by about $100 though - some real barn-burner video cards can cost as much as the rest of the PC but these are for the high-power gamers. As mentioned, consider if you want to hook it to a TV etc and make sure it has the required connectors and capability.
500GB is a bit small now days but unless you plan on storing videos or thousands of RAW format images it is quite adequate. The way I prefer to do things would be 2 drives so I can use the second one for quick backup and imaging. Not as secure as an external drive but a lot more convenient. Nowdays having USB3 on the motherboard instead of USB2 can make using an external drive (needs to be USB3) a lot faster for large data transfers.
Power supplies, yes, buying a better than the low-end supplies is a good idea but I've never had more problems with a cheapie than I've had with a brand name. Maybe just lucky.
The use of multi-core processors is better these days but I still think universal usage of all the available cores is not a given.
Do you plan to run this machine until it is virtually useless? If so you might add more weighting to the more expensive option.
If you are strictly a user and not a bit of a computer nut then the WalMart or other big box might give you bigger bang for the buck but they are often loaded with annoying crapware and some name brand computers can have proprietary parts that cannot be replaced with generics if they fail.
My preference is to select the motherboard and processor and take it from there. My preference is Asus followed by Gigabyte. However this requires you have a bit of understanding what it's all about. I also prefer to deal with a small computer store like you are doing.
The real place to start with a new computer purchase is to make a list of what you want to do and might want to do as best as your crystal ball works. It is likely the future use that is the problem. I have bought cheap and regretted it and I have bought the more expensive and regretted it! I used to work for a guy who said, if in doubt, buy the next one up.
Bill
