sander pad failure
sander pad failure
Kneale Brownson
sander pad failure
Kneale Brownson
The rubberish pad to which I stick sanding disks on my PC 335 ROS came loose from the plastic disk to which it is supposed to be attached.
Looks like an adhesive failure.
Any suggestions for reattaching?
Re: sander pad failure
Pad repair
Mainely,Bob
I have had good luck using 3M weatherstrip cement(otherwise known as "Gorilla Snot"). You can get it thru most well stocked auto supply shops.
Be sure to wear rubber gloves and let it set up well before you try to trim the excess off. If you`re anything like me you`ll end up with this vile, yellow,stringy stuff all over you if you don`t plan ahead and have a proper solvent close at hand.
Like roofing tar,I have a love/hate relationship with this product. I love how it works yet hate that I have to live with the residual crap on my hands,clothes,tools and bench until it finally wears off or I give up and throw the contaminated items away.
Re: sander pad failure *LINK*
Jesse Cloud
or you can get a replacement pad
replacement pads for ROS
Michael Wilkins
I had a similar failure with my Bosch Detail sander (the one with the triangle-shaped pad). I just used some contact cement to reattach the pad and it has worked fine since.
Jerry Roberts
Let me tell you about the 335. It is a POS. Mine lasted a little over a year mostly in the box. My pad turned to mush, and found out , according to PC, they dont make it or parts for it any more. I tried to improvise but nothing worked right. Good luck on the next one you buy.
Kneale Brownson
That list does not include my sander
Kneale Brownson
Kneale Brownson
I bought this thing years and years go and have used it regularly ever since. Other than the POS plastic dust tingy that broke on the first use, this is the first time I've had an issue.
Since PC is a thing of the past, I guess any of their tools will be hard to fix in the future.
I have several PC Sanders. They are ROS and I am not sure what the number is. Home Depot has replacement repair disks that you can just peal and stick. These are Hook and Loop. You sand the old hooks off and stick on the new disk. If the at is not your problem, I have repaired my foam disks I use on my lathe many times with CA glue.
Kneale Brownson
Kneale Brownson
I had a little tube of Locktite superglue that seems to have worked. I used the sander for half an hour today and the pad remained in place.
Never liked the hook/loop type connection for sandpapers.
