Mortiser machine
Mortiser machine
Mortiser machine
Lynn Reedy
Greetings from Soody Daisy Tennessee,
I am in the market for a new mortise machine. My normal preference is powermatic
but I have read several reviews that the pm. mortiser has a flaw in the handle area of operations.
Does anyone have any info about a good mortiser in the 1\2 hp. range? Also preference will be extended to American made equipment, if possible.
Thanks for your time and info.
Lynn Reedy
Re: Mortiser machine
Joseph Mulherin
Lynn, go to the Woodcraft link and view what they offer...both benchtop and stationary ones.
And if you buy one from them Ellis gets his pittence for advertising....lol.
Fred Davis
I have had Bench and Stationary Mortisers and the Powermatic 719A I have had for eight years is far and away the best of the bunch. Regardless of the brand machine you windup with , buy some Clico chisels and their cone shaped sharpener that fits a brace, you will be glad you did.
FredD
Re: Mortiser machine *LINK*
charlie belden
If you look at the PM 719A, consider the General International 75-075 as well. It adds the ability to cut angled mortises. Side by side comparison at the link below
General 75-075 and PM 719A comparison
Fred Davis
in addition to Lynn's comparison which doesn't address several things like price and using the wrong Powermatic model.
The General on the site I checked is 1,069.00 without a stand.
The enclosed metal stand is another 250.00.
The Powermatic 719A has a visible price tag of 799.00 and includes a well made steel cabinet. with storage.
To make the comparison more accurate , the Powermatic 719T has a tilting table which does the same thing a tilting column does and is more expensive then the 719A but considerable less then the General.
CPO has the PM and is doing a 15% off sale with free shipping for a item that costs that much.
Lastly it is a American company.
FredD
You won't find any new ones made in the USA
John in NM
While some of the companies are still based here, few machines are still made domestically, and I know of no hollow chisel mortisers that are made in the USA. If that's a big deal to you, you'll have to look for a used machine.
charlie belden
Checked the creation date of the web page I pointed to -it was Dec. 9, 2002. The comparison was of the two units available at the time - and the prices were about the same, though as you say, the PM came with a metal base, albeit a stamped sheet metal base I think had one sheet metal shelf inside. Considering that you'll have a set of bits & chisels, or two, the cone shaped chisel sharpeners, the stop bars you don't normally leave on the machine, etc. - a single shelf ain't going to do it.
If you're a woodworker - with a mortising machine - you're probably going to want to make a base cabinet - with DRAWERS - for the mortising machine. And since you're making it, you can customize it to fit YOUR needs. One thing I did was to make it taller than the sheet metal base units that most mortising machines offer. I HATE bending over to see things. So I built my base so the table of the mortiser is about mid chest height. Did the same with my sliding compound miter saw
If I were looking at something for cutting mortises I'd skip the chisel and bit mortisers - General or PM - and go with the Festool DOMINO. Loose Tenon M&T joinery makes things much simpler AND faster. And with the DOMINO, in addition to simpler and faster - add more ACCURATE. Now throw in the equivalent of an UNDO button - cut a mortise in the wrong place and you just glue in a loose tenon, saw it off flush and try again. Price is about the same as the General and PM - but a LOT more portable - will mortise end grain - and everything can be done on almost any flat semi-horizontal surface - with NO clamping required.
Consider getting the DOMINO instead of a mortising machine. But if you HAVE to have a good mortising machine - and you're in the San Francisco Bay Area, I'll make you a good deal on my General - with accessories.
DOMINO Review
George Colonel's Workshop-Havertown PA
Hello Lynn,
The PM and General are super machines, and when it was time to buy my mortiser, I couldn't afford the cost. Having scoped the bench top contenders, I test drove the Delta, Jet, and Fisch machines. I also looked at the Shop Fox #W1671, which had a heavier motor (8amps@3/4hp)and a longer plunge--9 inches. Further, the base was much more robust, and permitted head rotation for mortising off the side of the table into longer stock or subassemblies. The cost was slightly more than the competition for a much more capable machine. After several years, and numerous furniture items, I feel good about the Shop Fox, would certainly buy it again, and recommend you consider it. It is made off-shore.
George
I also married it to a cross slide vise from HF. It makes the positioning of the stock easy and fast, and holds it in place for accurate plunges.
George
