Freud Fusion!
Freud Fusion!
Freud Fusion!
Dale Penkala
I posted about a week or so ago about this blade vs the WW2 and got alot of good feedback. In the end I ended up going with the Fusion. I just got it today and tryed it out on some 1-5/8" red oak and just wanted to give my feedback on this blade in case anyone might be thinking about getting one of these.
1st I bought the blade from Amazon.com for 80.00 with free shipping. Once I got the package I could see why it was free shipping. Anyway I got it out of the box and the first thing I noticed is how sharp the blade was! Razor sharp! Got it mounted in the saw and double checked alignments and all and decided to cut the taper on 4 legs for a table I'm making out of red oak that was 1-5/8" square. This was done on a taper sled that I made and riped down the leg 25" of the 28" of length. Cut thru it like butter and I literaly can go right to 180 grit sand paper and probably go to 220 grit if I wanted to. Normally I would use 100 to take out blade marks. Couldn't believe how smooth the cut was!
I've read alot on this blade and most people say that it has the tendancy to burn ripping stock. I didn't see that with what I did this evening but I'm looking forward to doing more with the blade!
Something I wanted to mention to everyone that is considering this blade is in my original post it came up that Freud didn't offer any kind of resharpening service for this blade. When I took the blade out of the sheath inside was a folded up users guide and toward the back it talked about resharpening the blade and that Freud offers this service with fast turn-a-round times. I was really considering the WW2 just because of the resharpening service but now I'm really happy, not only with the blade but also the fact that they now have a resharpening service.
Thanks!
Dale in Mid Michigan
Re: Freud Fusion!
Re: Freud Fusion!
Thanks for the review, Dale. Sounds like you made a good decision. Now, let's see you make some tasty projects with the new gear.
Cheers,
Re: Freud Fusion!
Re: Freud Fusion!
Dale Penkala
Hello Ellis
Welcome! Already working on a picture table for the dinning room. That is what the legs I cut lastnight were to. Have some other plans to do that I will test this puppy out more on.
Thanks!
Dale
Mid-Michigan
Re: Freud Fusion!
Re: Freud Fusion!
Howard Acheson
Burning with the Fusion or the WWII is primarily do to not having your saw properly aligned. It sounds like your saw is set up correctly. The Fusion is a great blade- better than the WWII in my opinion.
Re: Freud Fusion!
Re: Freud Fusion!
Dale Penkala
Hello Howard
Yes I agree with you on the burning. I don't have any experience with the WW2 but so far with the performance of this blade I don't see myself trying one anytime soon.
Thanks!
Dale
Re: Freud Fusion!
Re: Freud Fusion!
Dave Paine
I have a WWII and a Ridge carbide. I have a 3HP Unisaw. My previous saw was only 1 3/4 HP. This meant I could only rip at slower speed and so I had more burning.
The Delta can still burn depending on the wood species, thickness and rate of feed. I get little or no burning with maple more potential with 8/4 stock, but can get burning with thinner purpleheart and cherry stock. I think this is due to the relative resin/oil in the wood.
I check my alignment periodically. I do not have a Freud Fusion to compare. The WWII and Ridge are close in performance. The Ridge rarely burns. The WWII gives a smoother cut, although the Ridge is almost as smooth. I do not see saw marks with either blade.
Re: Freud Fusion!
Re: Freud Fusion!
Howard Acheson
The owners of Ridge were some of the top folks at Forrest. The WWII and the Ridge blades are very, very similar.
