sort of OT sandblasting
woodenleg
I have done some sandblasting and bead too. How small of a nozzle can you get for sand blasting? I want to blast a picture in wood using a needle like nozzle but I have looked a little on the net but very little luck. Do needle nozzles have a different name? I have a small blast tank from HF but getting ready to order a bench top multi media blasting box from NF. Any help would be greatly infused into the thinking. Thanks, Dave
Re: sort of OT sandblasting
Clint Searl
Clint Searl
Blasted graphics are made using a mask.
Clint
woodenleg
I understand that but I want to have good control over the blasting as the pictures will be small and there fore the wood also. If I am good at this I have orders to blast pictures on to antlers. Dave
If the item is as small as antler
Gary Smyth
and if you want detail, I'm thinking that a laser might be the better alternative. Well defined sides on letters for use on granite markers cannot be held much below 3/4" with the best sandblast equipment and rubberized mask. I'm not sure that any standard abrasive can be controlled much below that size even with a computer controlled needle nozzle. Maybe someone has evidence to the contrary. I'm paying attention.
Jim DeLaney, Austintown, Ohio
Re: sort of OT sandblasting *LINK*
Try an "air eraser." They're sorta like an airbrush, but use an abrasive medium.
The link is to a higher end one by Paasche, but even Harbor Freight sell them.
Mine (which I haven't used for years) is a Paasche, and it came with sever different grits of abrasive. It works very well for etching glass, and if you hold it in one place long enough, it'll bore a hole clear through a glass or cup.
Air Eraser at Amazon
Research sand carving *LINK*
Dick Coers
These people blast really fine and at low pressure. Here's a reference for a really popular gun. Pricey, but really high rating.
PAB blaster
Don Evans
There is a company call SCM that specializes in all type of setting people up with there equipment and other stuff so one can start there own business.
Allong with the high speed turbine cutters that many woodworkers use they also have one section that is for blasting. Even the equipment to make you own masking stencils for blasting glasses (like you drink out of), stone etc, truck windows (rear) and lots of other suggestions.
Don
SCM
I've no problem with them, but be
Gary Smyth
sure of what you're getting yourself into. Even on their top end $11K system they do not include a compressor, or Photoshop (if you want to do other than letters and clip art). Their heavy duty mask (at over $100 a roll 15" x 30') is 42 mil thick and that requires a powerful motor for the cutter that has to be very sharp (at nearly $30 each) - to say nothing of a cutting machine that can handle the heavy mask and hold everything in registration. They have been around as far as I remember for over 20 years, so that's good, just be sure before you buy.
Steve Strickland
Re: why sandblast?
Steve Strickland
I was sort of wondering why sandblast myself. Seems similar to acid etch to me.
Lasers will burn wood and antlers alike, so they are limited in what they can do. But yeah they can burn very small details. They don't burn evenly in natural materials which have density variations.
The Dremel is pretty popular for freehand carvers. If you want automation then they have the CNC mills, even small benchtop ones, that can do the tiniest detail even on round 3D objects such as cue sticks.
charlie belden
I've got the Harbor Freight $25 air eraser and use it for removing the charring/scortching of low relief 3D laser engraver "carving". With 220 grit aluminum oxide medium it doesn't abbrade much - not like my little cabinet blaster shooting sand. But even with the finer air eraser, fine detailed "drawing" with it probably can't be done, Pasche, best known for their airbrushes did have a fine detail "air eraser" but I've never used one.
What I'd look into is laser engraving and the use of an "air eraser" to remove scortching if necessary. And once you have your pattern and the laser set up, you can do multiple copies pretty quickly.
Have a look at the images on the attached link - and if you want a primer on laser engraving follow the link back to the laser engraving table of content page and go from there.
Laser low relief "carving" example
Steve Strickland
Re: Lego 3D carver  *LINK*
Lego 3D Carver
