Illustrated story line of 4 legs.... *LINK*
Hikmet C. Sakman Victoria, BC CDN
These pictures should be in order and they should make sense without words. Where these legs are attached will be the next post. Wedges are quilted maple, dark inlay pieces are 1/16" thick macassar ebony, feet are wenge, 4 pieces of 2" stock cut to 1-3/4" pieces and each foot took 4 pieces to make up 6"x6" squares.(11th. picture.) then went through thickness sender, which that procedure was not fotographed. So, counting each foot as 4 pieces, 32+4=36 pieces of wood pieces glued together to make up one leg. Ah, 37th. piece of plywood on top for mounting on the lathe as well as to the table. So the story goes...
Chico...
