Bench Light
Jerry Gibbs
I have signed up for a woodworking class. An optional piece of equipment is a bench light. Is a bench light like a desk light with an articulated arm? Any suggestions welcome.
Bench Light
Jerry Gibbs
Re: Bench Light
Phil Joines
I'd want an articulated arm with an incandescent bulb rather than fluorescent. With incandescent at an angle you can see sanding scratches and tearout much better than with fluorescent.
Re: Bench Light
avalon
Friend of mine has the gooseneck shop light from craftsupplies... im going to get 2 when i get my shop done...
they call it the stayput work lamp...
Re: Bench Light
Randy Johnson
I�ve bought three different adjustable lights over the years and have to say that this is the best one.
http://www.woodcraft.com/Product/2021277/26141/WoodRiver--LED-Dual-Power-Shop-Light.aspx
It�s small so it doesn�t get in the way. It�s LED so it doesn�t get hot. It�s bright, and adjusts to exactly where you want it very easily. Although I always use it with AC power you can even use batteries in a pinch.
Currently it spends most of its time on the bandsaw but it makes its way to the lathe every once in a while as well.
Re: Bench Light
avalon
http://www.woodturnerscatalog.com/store/Shop___Safety___Shop_Supplies___Stay_Put_Work_Lamp___stay_put?Args=
Oh so true ! . . .
steve mackay
I guess, at the moment here in Texas, I'm an outlaw. A bad human being with no regard for the planet. If I'm woodworking, reading or pick'n splinters I want a "LIGHT BULB" ! I don't have to smuggle 'em across the Rio Grande yet but probably will soon.
