Kicking around ideas for an "angel" display table
The prayer shawl ministry group has an "angel" made out of grape vine. It is "decorated" with hunks of yarn and stuff. They now want to display it in the Parish Hall. Fine.
The "feet" or "base" of the angel are basically the ends of grape vine.
My basic thought is to have a table with either a lip or an inlaid "bead" so the angel won't go "skittering" off of the table. Then I got to thinking - what about wood movement? I won't have a problem along the grain with wood movement in a solid table top, but I will have a problem across the grain.
So - what do ya'll think about gluing up the wood for the table top and cutting off the ends and the sides and then using that wood for the bead? I could put a reasonable profile on the bead. Not too much of a problem along the grain. Do you think the bead made out of the end grain pieces would be too weak?
Another thought was to just make the cross direction beading material the same way that I was making the other beading material, but make it "floating" and anchored only in the middle. I'd have it protrude slightly past the other beads. It would be even during certain seasons.
