OT - styrofoam insulation with foil
Terry Alexander
I inherited a 4x8 piece of styrofoam insulation that has some "foil" on one side. I want to cover my attic access with a piece of this. I have the access where you pull down the stairs and climb up. I'm not going to "engineer" or "build" anything, I am just going to cut a piece large enough that you can lay across the opening as you are going down. Thus the styrofoam (light weight) and easy to move in and out of the way.
So, here's the dumb question:
Does the foil side point up or does it go down?
TIA
Terry Alexander in West Texas
Re: OT - styrofoam insulation with foil
Steve Strickland
Re: It points up if ...
Steve Strickland
you want to reflect heat away. If you want to reflect the heat back in point it down.
That stuff works a lot better than it's R rating suggests.
Yonak
Terry, that's an excellent way to save energy and heating costs. I have a pre-made foam contraption that does the same thing.
Remember that when the pull-down stairs are put up they will push up on the foam negating the barrier. The device I have is, basically, a box without a bottom, with 9" vertical walls allowing a space for the stairs to go into. Maybe you could fashion something similar with your Styrofoam sheet, perhaps using hot-melt glue or something.
Good advice so far. I have done a bunch of these.
There are claims that it doesn't matter which way the foil faces. The problem is that if the foil face up, it will get dusty and that kills the reflectivity. If it faces down it will tend to stay clean and more reflective.
The process is that you should go up in the attic and have someone shut the hatch so you can see how high the ladder rises above the framing. I suppose you could fold up the ladder and measure vertically from the plywood hatch and figure out how high that would be above the framing.
You need a flat continuous surface around the perimeter of the opening.
Make a box out of your styrofoam that will fit over the ladder and the perimeter should seal to the floor. around the opening. It would be a good idea to put some sticky back soft foam weatherstripping around the opening.
So the box sits over the opening like a hat. It helps prevent both heat loss/gain and air leaks, a second major source of heat loss.
Do a nice job of the fitting and selling, both to the floor and in the box itself.
The box should be heavy enough to seal firmly. Some people hinge them so they can tip out of the way. Some rig up ropes and pulleys with counter weights.
My neighbor complained bitterly about how cold his hall was in the winter. I finally talked him into making one of these. He was so pleased he made four more for friends.
And the others are right, you can buy several different versions of this if you like.
