cutting slate not OT
John Veerkamp
I'm making a small sofa type table 14X34. I have a piece of slate about 3/8 thick that I want to cut for the top. What's the best way to cut it to size with nice straight edges, The top will be dropped into dadoes routed into the skirt. I thought about getting a diamond blade like used for cutting concrete siding that fits my circular saw. Those blades are fairly pricey ($60) for a one time use. Is there any better way?.
Thanks,
John
Re: cutting slate not OT
I would spend some time on the phone
Gary Camp, Bend Oregon
I'd bet money somone in your area has a wet saw (or maybe a dry saw) that can make the cut a lot cheaper. The mason I used for my wood stove hearth was able to cut a slab 36" wide 72" long off of a block of black welded tuff.
glc
larry in Memphis,Tenn
John I just looked at Lowes web site and they have a 4 1/2" Diamond saw blade for $20, that is what I have used for over 5 years to cut tile, ceramic, and other such material. I`m sure it would cut your slate. Good Luck. Larry
Check the Borgs
I have a 7-1/4 dry diamond blade for my worm-drive that cost me $20. I figured it to be a one-time use when I was cutting 3/4" slates for a walk. 10 years later I still have the saw and the blade, and both still cut.
Note: A dust mask is required and the saw must be carefully blown out after use or you can kiss your commutator and brushes (if not the bearings as well) bye-bye.
FredD
If it is a one-off job John, I would go Gary's way ,any number of facilities exist for cutting Stone, in addition to what Gary mentioned, you may live near a Monument company , Granite counter top place.etc
Should be much cheaper to farm out the cut then buy a blade you never have used and then only use once.
FredD
I have recently installed a bunch (for me) of ceramic tile. Three tub surrounds and a floor. I bought a cheap wet saw at Home Depot. I think it was about $80. Its a piece of cheap crap but has served me well enough. It comes with the 7+" blade Mark mentioned.
I also agree with Mark. You could buy the blade for about $20 and cut it with a circular saw. Mark is right. Prepare for huge dust. Wear a mask and clean your saw thoroughly. You may have to remove the guard to get all the dust out of the grooves so that it will operate properly.
So, if you want to do it yourself, you can, but I also recommend having the pros do it with a wet saw. Much less expensive and much safer for you and the slate. Very little danger of cutting it wrong or breaking it and probably cheaper than buying the blade or other paraphernalia. I would make a template for whoever cuts it so that if they fit it to the template it will fit your table. That way there is not misunderstanding and no excuses.
Re: Harbour Freight saw
works well for me. I was installing ceramic tile on my front porch a couple of years ago - HF had a sale on the wet tile saw - As I remember it was about $30, I figured it might last the job. I didn't think the blade would be much good so I bought a spare. I did that job, this year we remodeled one bathroom, installing Quartz tile on the floor. The saw still works as well as when it was new and the blade hasn't shown any wear yet. Another option, Lowes in Lafayette, Indiana does have a tile saw in the tile department with some signage indicating they will cut tile for a price - didn't read it but if you have a Lowes near you you may want to call. They also carry saws for around $50 similar to the HF saw.
Note what Mark says.  I've done it
Ray Thompson- Middletown, IN
the same way and the dust cloud that is created is really something.
Ray
FredD
The template idea is a good one, it eliminates "you said" -"he said"
FredD
John Take it somewhere and have it cut. I used an abrasive cutoff wheel mounted in my table saw. I have a dust collector hooked up to my saw but I put another hose right next to the blade. I could see it suck up the black dust and was really proud of myself. However when I finished I noticed the whole shop was black. It took weeks to clean it all. My table saw is open with the motor on the back. apparently it didn't damage it because I've been using it for the last 15 years. However I don't want to put up with that mess again.
Kneale Brownson
Kneale Brownson
I had to cut the corner off a cement slab that overhung where a sewer pipe I was installing HAD to go, so I rented a big abrasive wheel saw from one of those rental outlets. I noted at the time they had a smaller version that, if I recall correctly, would be great for your task.
However, as others note, this task is messy, loud and subject to errors that having a shop do to fit a template would eliminate.
JMOHNIKE
You can get a masonry blade for an angel grinder, cheap, works but slow.
Joseph Mulherin
John, I have to agree with the others in saying you should take the slate to Lowes or another business and let them cut the material. Also, remember the "black lung' diseaswe of the moners in the coal mines....they breathed in the dust and got very severe breathing problems which caused them many health problems in later years. Cutting that slate and they dust involved is very dangerous to your lungs, so take the slate to someone who has a water saw and have done with it.
Stephen Shepherd
Or
Stephen Shepherd
You can cut slate with a hacksaw.
Stephen
Re: Slate is prety soft stuff
Dale Stansbery
I made a bumper pool table eons ago and cut the holes with a coping saw and regular blade. You could probably cut it with an old cross cut or rip saw if you were ambitious enough. You may have to resharpen a time or two and maybe take a breather for a cold drink now and again.
