Anybody need some Lexan?
I have a friend who buys stuff at salvage auctions and resells it. He recently scored some sheets of what appears to be Lexan that is about .20" thick. Its clear plastic in 4' by 8' sheets. The sheets are dirty but when you pull the protective plastic film off, they come out clean. He has more than 25 sheets. $25 an sheet. If you are local to the Richmond, VA area you could pick it up or if you needed it I could cut them down and ship them.
Hope the Hosts don't take offence at the blatant pitch (Delete the post if you do), but at this price the stuff is cheap and I just thought some of you might find it useful.
Re: Anybody need some Lexan?
John McGaw
Actually, I'll be in the market shortly but my use requires that I use stouter stuff since it will be for a safety partition at the side of an open stairway. I figure that I'll be needing something close to 1/2". I cringe to think what that will set me back...
larry in Memphis,Tenn
John If you can get it somehow, could you put two togegther, that would be very close to 1/2". For what that would save you, you could drive a good distance. I wish I lived closer. Larry
