Well pump failure..... a back up system
Frank G
Last Sunday lightening claimed my son's well pump. It was 182 feet down and not an easy task clanging it . It is done and then came the time for reflection. He hit me with one today that really sounds great.
The biggest problem with losing your water is the toilet. You can buy bottled water and you can skip a shower for a couple of days but the toilet , just call it a pressing demand.
The system would involve a non- potable water catchment tank receiving water from the house roof. You would then tap the tank with flexible tubing connecting it to an RV style 12 volt on demand pump. You would run the delivery side of the pump to a "t" at predesignated toilet. Install a shut off line a little way up stream in your house plumbing. The battery would be connected to a trickle charger. You are ready> If you are not in Fargo ND a little salt in the water will guard the system for most of the winter.
I am ready to start putting one together. FFG
