bed repair help
bed repair help
bed repair help
Most furniture I've repaired that has been nailed together by an amateur I can usually get apart for repair. The nails were in a hidden place and I can tap my needle nose vice grips in far enough to get the nail head and then pull it out using pry bars on the vice grips or a lot of elbow grease. Then I'll steam the dent left by the pliers and much of the problem is gone. However it's still noticeable.
On pieces that will be painted I simply gouge out an area big enough to grip the nail and then drill out this gouge area later and put a plug in.
These nails are buried flush or even below the surface a little and it's in a spot that will really show if I use the above methods.
Does anyone have a good way to get them out. I could try to drive the pieces apart with a mallet which I've done before, it tears a slot in the tenon but that's hidden on assembly. However the side grain on the piece that goes into the tenon will break before the tenon in this case.
Re: bed repair help
Re: bed repair help
Bill Turpin in WNC mountains
If matching wood is available, make a plug. remove brad with your method. Drill out dent with forsthner and install plug. Plug looks like it needs to be cross-grain not end-grain.
Re: bed repair help
Re: bed repair help
Stuart Johnson
You could possibly use a very small center punch or rod and drive the nail through the piece to the other side.
Re: bed repair help
Thanks Bill and Stuart
Stuart I thought of that as I was making my lunch. I have done that before and it works but had forgotten it. That's what I'll try. Thanks.
Re: bed repair help
Driving the nail through wouldn't work
There were routed details on the top side that would have been damaged. I used a brocken screw extractor bit to drill around the nail. Then pried out the wood around the nail and used my needle nose pliers to pull the nail. Then I drilled out the hole with 3/8" bit and used a plug cutter to cut matching plugs.
The mineral spirits is working great at getting rid of the Duct Tape residue. I've reglued some brocken areas and now have to clean up an area that's missing and make a patch. Should be able to glue it all back together tomorrow.
It's a lot of work for free but sometimes you just gotta do what you gotta do.
Re: bed repair help
Re: Driving the nail through wouldn't work
woodenleg
I have never tried this with a nail but I have used JB Weld to "glue " a nail with a cut off end to a roll pin to pull or drive it out ( I didn't have the right tools ). It might work to pull the nail out. Dave
Re: bed repair help
Extractor
Just as you can do for snapped screws, you can make (or buy) a screw extractor that bores a hole around the embedded metal, allowing you to grip the item and either pull it out (nails) or unscrew it.
Make one with a 5/32" drill and a piece of 1/4" O-1 drill rod by drilling a 1/2-3/4" deep hole in the end of the rod, then champher the bore to get a sharp edge, and lastly, cut some teeth with a small "v" file. Chuck it in your drill and bore around the nail, then grab and pull it out. You still have a precise 1/4" hole to plug with either the same or a contrasting wood. Since the plug will show, trying to match grain across 1/4" is a waste of time. I'd prefer a contrasting wood dowel that may also operate to "peg" the tenon.
Re: bed repair help
That's what I used Mark
Re: bed repair help
Duh . . . Missed Followup Post!
