REAL MILK PAINT
Cleaning a Wood Rasp
Paul Leuba
I use a Nicholson #49 wood rasp to shape several parts while building Windsor chairs. The tool has become less effective at cutting because the teeth are loaded with small wood chips that are lodged tightly.
How can I clean these chips from the rasp without also dulling the cutting teeth?
Paul in Hunt Valley, MD
Re: Cleaning a Wood Rasp
Hardware stores sell small wire brushes that look like the Hulk's toothbrush; mine has them in the paint aisle, because painters use them for prep work. Don't get the steel bristles. I'd try the fiber bristles first, then the brass bristles if the fiber won't do it.
If you have a choice, get brushes with wooden handles; I find the plastic-handled brushes flex more and thus work less effectively.
Re: Cleaning a Wood Rasp *LINK*
Jesse Cloud
Do you have a file card? Soft brush on one side, metal bristles on the other - should keep that rasp in good shape!
file card
I use a brass brush and if that doesn't work I use a file card as mentioned above. One or the other has always worked.
Galen Vetterick
Look in the same area you buy a file or rasp. You will find a file card and brush. Wood handle tool with very short say 1/4" bristles of mild steel on one side and short fibre brush on the other side. Steel brush is "softer than the file and will not damage the file teeth.
Re: Thanks Everyone - File Card it is!
Paul Leuba
I'll get one at the local Woodcraft store.
Get the file card mentioned above, they are very effective. Will make files and rasps seem like new, for a while.
Also, there is a company you can send your rasps and files to they will sharpen them. I used to have them book marked but had a computer crash and lost the bookmark. You could try Google or maybe somebody here will remember. Not that your rasp needs to be sharpened, but it might.
On the Wood Works show that David Marks had on the air several years ago he showed how to sharpen them. I believe it involved sticking them in an acid bath for a while, but I am not sure. I don't know if his stuff is still on line. I have to admit I was amazed that they could be sharpened. Wonder how many I have dogged to death and thrown away?
Sand blast them, side benefit is sharpening
Ray Thompson- Middletown, IN
of the teeth. Back in the late 50's when I worked at Nicholson we sand blasted all files for a final sharpening before packaging. It also removed the rust from storing the files in water but that is another story.
Ray
Card file for  Cleaning a Wood Rasp
del schisler
Clint Searl
Soak it in water or mineral spirits...
Clint Searl
....Then just brush out the soggy chips with a welder's wire bristle tooth brush.
Clint
BTDT
The sand blasting, NOT the water storage ;)
Water Storage of files
They were stored in water between operations after heat treat (not before). The rust rate is known and predictable in water compared to air that varies in humidity. A quick sandblast to clean and sharpen and they were good to go. For heat treat they had to be dry as a bone because they were heated in molten lead and a single drop of water would blow a lead pot apart with bad results.
Ray
Re: Soak it in water or mineral spirits...
Paul Leuba
I used the file card and removed most of the chips quickly, however, about 5% of the chips would not be removed with the file card alone. After a good soak in water, the remaining chips came out quickly.
Thanks for the tip!
Clint Searl
Also...
Clint Searl
Put new life in clogged sanding belts by soaking in slightly soapy water overnight and scrubbing with a fingernail brush.
Clint
Re: Also...
A Jeweler's Trick
charlie belden
My jewelry making mentor showed me a trick that kept metal files from packing with gold and silver. Rub a piece of chalk "against the grain" and the chalk will pack in to the area that metal would otherwise pack into and be almost impossible to remove. Works great on fine and medium metal files. Just might work for semi-coarse rasps as well. Use big SideWalk chalk - and save the meat on your finger tips ; 0
Re: A Jeweler's Trick
Not just jewelers, I learned that trick in my machine shop class. Chalking a file works wonders when filing brass and copper. They really want to clog up files.
Bill Howatt
That brought back a memory that had been lost. I was taught that in a grade 7 metal-working class and we were filing steel.
Thanks for the memory and the reminder.
Bill
Yet another trick
Mainely,Bob
Warm the file in the sun (or the oven while SWMBO is out shopping) and rub a little beeswax into it, this will help to keep it from loading up and also help keep it from rusting.
If you live on the coast (like I do) chalk will attract moisture and cause the file to rust.
For those really heavily loaded files just run a bit of copper at 90 degrees to the direction you normally file in to dislodge the jammed metal.
I am wondering...
if the chalk trick would work on sanding belts for the drum sanders. I had a terrible time sanding some heart Pine. Sand one piece and soak the strip in Simple Green. Wonder if chalk would help?
