Re: sick computer
Re: sick computer
Re: sick computer
james runchey
Gonna pickup a new monitor and am undecided as to a 20" or a 19". We have an 18 now. Any thoughts? It's only used for surfing and E-mailing.
Re: Re: sick computer
Re: sick computer
John McGaw
If you are going from an old CRT monitor (assumed) to a flat-panel monitor then even in pairs with identical 'size' numbers the flat-panel will be larger. But watch out for wide-format monitors; some people find that they need a larger monitor to have it feel right. Personally, I figure that a 23" is good. In fact I have two of them stacked vertically on a custom made mount. Then again, I spend a lot of time in front of them rather than doing anything useful.
Don't forget that as you get older the stuff on the monitor will seem smaller and fuzzier so going larger is a good idea.
Clint Searl
An inch here, an inch there.....
Clint Searl
And pretty soon you're talking about a whole inch. Whew! :b
Clint
Re: sick computer
Gary Smyth
Whatever size you select get a wide screen monitor with an aspect ratio of 16:9 or 16:10. Many films are made for wide screen and the old tube 3:4 ratio (it's not the same) cuts off part of the screen with film/graphics in the newer format. This is especially annoying if there are lower third captions. I have a 20" diagonal and I would prefer a 23".
Re: sick computer
Jerry Nicholson
I think this is one of those things where bigger is better and if I were buying a new one I wouldn't go any lower than 23 inch. 1080 x 1920 resolution, of course. I have had good luck with Samsung and Acer, both of which came with cables.
Jerry
Check if Cable included.
Bill Howatt
I don't know if the situation has improved since I bought mine a couple of years ago or so. Not all brands provided the digital DVI cable or possibly even the VGA cable. Both should be provided even though you will probably only use one.
Bill
