THE WOODRAT IS BACK!
Message sent to IT Dept. (OT)
Moses Yoder
Moses Yoder
My computer has been slow waking up in the mornings. I just log off at night usually, but even if I shut down it takes a long time to start up. This morning I timed it, over 13 minutes. Once it's started it works fine. Thanks to FredD's advice last week, I think I may be able to help the IT dept. fix it, so I sent them this message this morning.
" I timed my computer this morning and it took 13 minutes 26.52 seconds to wake up from hibernating overnight. I am getting an HP printer notice of some sort when the computer screen comes to life, and I think that may be delaying the start up. I printed the screen so you can see the window that pops up; perhaps sometime when you get a chance you can look at my computer. I did find some helpful advice on-line and thought I would share it with you.
Why Computers Sometimes Crash! by Dr. Seuss.
If a packet hits a pocket on a socket on a port, and the bus is interrupted at a very last resort, and the access of the memory makes your floppy disk abort, then the socket packet pocket has an error to report.
If your cursor finds a menu item followed by a dash, and the double-clicking icon puts your window in the trash, and your data is corrupted cause the index doesn't hash, then your situation's hopeless and your system's gonna crash!
If the label on the cable on the table at your house, says the network is connected to the button on your mouse, but your packets want to tunnel to another protocol, that's repeatedly rejected by the printer down the hall.
And your screen is all distorted by the side effects of gauss, so your icons in the window are as wavy as a souse; then you may as well reboot and go out with a bang, 'cuz sure as I'm a poet, the sucker's gonna hang.
When the copy on your floppy's getting sloppy in the disk, and the macro code instructions is causing unnecessary risk, then you'll have to flash the memory and you'll want to RAM your ROM, and then quickly turn off the computer and be sure to tell your Mom! "
Moses Yoder
Engineering Department
Re: Message sent to IT Dept. (OT)
FredD
:D :D :D :D :D !!!
