OT sick computer
OT sick computer
OT sick computer
james runchey
My wife was on the Dell desktop this morning, XP, when all of a sudden there was a flash of light and the screen got all convoluted. The side margins are greatly curved inward top to bottom on both sides. In addition, on the right side there is a band, maybe 1/2" wide, much brighter than the rest of the screen. The text in the center of the screen is very blurry. Rebooted, and came up the same way. Any ideas?
Re: OT sick computer
Moses Yoder
Moses Yoder
My wife had a customer come up and for some reason they got to talking about computers. He was an older man, and said he readily admits he knows nothing about computers. My wife is an extraordinarily wise woman, and was able to tell him everything you need to know about computers in about 1 minute.
1) Get a handgun, preferably .44 magnum.
2) Cock the gun, aim at the problem area on the computer, and pull the trigger.
3) Problem solved.
Stuart Johnson
It sounds like you have a bad monitor. Try swapping it with another. If all is okay it's the monitor if not it might be the video card but I would think that is either good or bad. FWIW, all I know about computers is you let the smoke out they stop.
Bad monitor
John in NM
From what you describe, your CRT monitor has gone on the fritz. There are circuits that control the horizontal and vertical sweeps using magnetic fields between the electron source and the screen of the CRT. Sounds like there's a fault in one of those circuits. Get another monitor and the problem will be gone.
David Yoho
The first thing to try is the monitor. You could either plug the one in question into another computer and see what happens or plug another one into the Dell and see. Flat screen monitors are pretty inexpensive now in case you have to replace the old one.
If the monitor checks out okay, then it is time to replace the video card, unless the Dell does not have one and is using on-board video or what is referred to as "integrated" video. In that case you still may be able to install a dedicated video card, if your motherboard has a slot for one and then you need to disable the integrated video in the system BIOS.
filter  capacitor  open up in power supply
del schisler
that is a sign a filter cap has open up in the power supply. This happen's in tv's also. I have been in repair for 50 yrs and have seen this lot's of time's. Now a good repair man could find the cap that is open and install a new one . Probly cost more than the unit is worth. If you could get a power supply from a comp. place they cost is very cheep??? Depend's who you deal with . good luck
Jerry Nicholson
The first question should be: are you using a CRT monitor or an LCD?
Jerry
Re: filter  capacitor  open up in power supply
Dave Paine
Good diagnosis. Monitor rather than computer. Also agree rarely worth the cost of repair.
Get an LCD. Will also save on power consumption, although may not last as long as the old CRT. I have had two LCD failures after a few years. Another example of not worth repairing.
