Router table fence questions
I own a Porter-Cable 698 router table. I've been using a Hartville aftermarket fence, but am not entirely happy with it; and am about to mill some crown molding that will require a hold-down that mandates a higher fence.
I am thus considering whether to build a higher fence. The design I'm considering is somewhat like this:
I forgot to note that the fence would be fastened to some aluminum plate, probably 1/4", resting on the table. Not visible in this funky drawing is the method of holding the fence down - probably plastic wing-nutty things into the factory threaded holes in the tabletop - and the large-section aluminum angle stock that would go between base and fence.
The plastic facing down at the bottom of the fence, scavenged from the factory fence (itself a terrible design), would allow me to close the opening in the fence to just accommodate the bit, so as to minimize stock diving into the opening.
Oh, and I'll have dust collection on the back side of the fence.
I have three questions:
1. How does overall design seem?
2. The tallest bits I'm ever at all likely to use are vertically-oriented panel bits, about 2-1/4". I'm thinking a 2-1/2" high opening in the fence would be more than enough. Am I missing something? Are there problems with an opening this high?
3. As far as overall height, 5" seems enough to me; comments appreciated, though.
Re: Router table fence questions
George Colonel's Workshop-Havertown PA
Good Evening Bill,
I've used architectural/crown molding bits on several occasions, but am more prone to the horizontal design for panels for furniture/door items. I also use a Penn State Industries alumiinum fence. I just measured the height and find that it is six (6) inches.
I'm sure a less high fence would work, but if you have the option, I'd recommend you go with the extra support a six inch high split fence would provide.
George
Thanks
I had to read that post through twice, looking for the puns...
I do appreciate the advice; good information.
That's pretty much what mine looks like, Bill
Bruce, a MN Galoot
except it's made of plywood, not aluminum angle, and has no T-slots. The height, gussets and the rest are pretty much the same. The tallest bit I've used is a 2" spiral carbide cutter and there have been no problems.
For hold-downs, you could use homemade finger boards simply clamped to the fence and the table. The price is right.
Jesper, Denmark
Jesper, Denmark
Hi Bil,
I think I have had success with the Norm inspired router table and fence. On principle, I prefer wood to aluminum construction - you always get a better idea during the construction, and wood lends itself better to on-the-go chjanges.
The original fence with slot width adjustment is partially hidden behind the taller auxiliary fence, which basically stays on all the time. The aux fence is 10" tall, which helps, as you can attach various fingerboards and other guides to it with clamps, screws or whatever. It also adds stability when routing edges of sheet type goods, presented vertically.
Construction is a combination of plywood and black locust. Location of knobs etc should be obvious from the pics, but it basically follows Norm's original plans. The chip/dust extraction functions very well.
Another version
Gary Smyth
This may be of help. Works here. Height of fence is actually 7 3/8" with a 1/8" dust channel at the bottom of the fence when it is set properly.
