DeWalt 2-speed Planer
Janice Manuel
After 20+ years of dependable service, my Hitachi planer died today....I don't need/want a big machine. I also need a new planer soon....
How does the DeWalt planer work? The reviews are mixed for it...if not that one, what other one would you reccomend?
Re: DeWalt 2-speed Planer
del schisler
i own the ridgid 13" planer it is a 2 blade. Comes with a extra set of doubble edge blades. also has a lock down head for snip. It also has a life time warrenty. This planer work's perfect out of the box. i have had mine sence they first came out Don't remember when now but it has been perfect. I use it 4 or 5 time a week every week so it doesn't colect dust. Here is a google search pick out some of the review's
http://www.epinions.com/reviews/Ridgid_13_Thickness_Planer_TP1300
I have had the DW 735 for quite a few years. I've liked mine. Would I get it again - probably - but it is getting pricy.
Negatives - price, weight, really needs the infeed and outfeed tables.
Positives - performance, finish, accuracy, two speeds.
As Del said, there are other good machines out there. I like my DeWalt - but I would look really hard at some of the others.
Brian in SLO
I have no complaints about my DeWalt.
I like the two speed feature and the 3 blades. Just make sure and use some sort of dust collection because the exhaust fan will blow shavings out the back and all over the place if you don't.
The downsides to me are the inability to re-sharpen blades and the lack of a head lock, although that has never really caused any problems.
Overall I have been pleased with mine.
kellyanderson72 yahoo.com
I have had the DeWalt 735 since about the time it came out and have had no problems with it. I have the DeWalt stand that makes it easy to move around and puts it at a good height and the added tables which are nice but I used it for quite a while before I got them and never had a problem with snipe. It is a little loud but I think that it is a good planer.
AZ in Colorado Springs
I have a 13" Rigid with three cutters. I got it in May '10, a reconditioned unit from an outlet mall -- was about $100 less than a new machine. I've used it quite a bit and it's been super. I use a Rigid shop vac to catch the chips, and it gets about 90% of them. Otherwise, there's a huge mess to clean up.
Dave Paine
Last I looked DeWalt had more than 1 model. I have the 735 and like this, as do the other replies.
It is supposed to have an automatic head lock. Hard to tell. I would prefer knowing how to tell it is locking. I do get some snipe. May be due to needing to tweak the infeed/outfeed tables - again. They are loose fit at the planer.
Dust collection is highly recommended. DeWalt state "fan assisted" dust extraction on the unit. Should be more like "jet assisted". This generates impressive velocity.
All the box planers are noisy, and this feels to generate more noise than the Delta 22-580 which it replaced.
I like the 3 knives, gives more cuts per inch. Knives are beefier than the Delta and you can get better replacements from Infinity Tools, just more expensive.
The 735 is better considered a stationary planer, unless on a table with casters. This unit is very heavy.
I like the height adjustable handle on the side, and the open design. Easier to keep clean.
If I were in the market I would also look at the Delta 22-590. This has 3 knives and supposedly improved hardness of the blades. The 22-580 blades nicked too easily.
