Sculpting a chair seat Questions
I am making a "Charley horse" like the one Wally Dickerman posted over the turning board. Its a little rocking chair with a horse head for the little one to hold onto.
I was wondering if I should sculpt the seat? I don't have a scaup or any other carving tools. Anybody got an idea how to shape the seat any other way? I have routers. Just no carving tools. Maybe I should leave it flat.
Re: Sculpting a chair seat Questions
I thought everyone had a scorp and a travisher.
For hardwoods (as opposed to softwoods), I typically use a 4 1/2" angle grinder with a "Lancelot" chain to start. I also have some tungsten grinding wheels (donut or bagel shaped). Woodcraft now sells the "Galahad" version. These can be quite aggressive. They come in different degrees of coarseness or fineness.
I also use 24 and 36 grit sanding disks with the angle grinder. These work well with softer woods (pine, poplar, etc.) as well as in cleaning up the marks that the grinding wheels make.
The disks aren't inexpensive - but you need to only buy it once. If this is a single project, I would just go with the sanding disks (assuming you have the angle grinder).
Clint Searl
Me too
Clint Searl
I have a scorp, no travisher but do have a pull gouge that works pretty well. I also have a curved spoke shave that I use for final clean up. I use an angle grinder also. I have one of the chainsaw bits but have also used 24 grit paper discs. They are safer althought they raise dust rather than shavings. Many many years ago I did it with a router. I built this arcing machine that let the router swing in an arc. By moving it at different angles I got a pretty good looking seat. It's much faster and easier with the angle grinder.
I now have one of the mini arbortec's and it is also a good tool for this.
Moses Yoder
Moses Yoder
This would be a good excuse to buy the Pull Shave from Lee Valley.
What you could do is route different depths with your router, terraces if you will, then put a 36 grit disc on an angle grinder and finish sculpting it with that.
Paul Leuba
I have been building a few Windsor chairs with a rather deep seat profile of up to 1" - 1 1/4" at the deepest. The first tool I use is a gutter adze to rough out the blank to dimension, then I use a 2" gouge with a #7 sweep to shape the profile to approximate final dimension. This is followed with a 5" ROS with 80 grit before hand sanding to final smoothness.
It takes a couple hours for each seat, but I find that the mostly hand done process allows me to carefully achieve the profile I am after.
Paul in Hunt Valley, MD
Joseph Mulherin
Somewhere I found the plans for a jig that you can slide your router on using a straight bit to do the work.
Basically, it is a bottom box 24"sq using 1x4 boards. Side boards are verticle with two boards 21 1/2" screwed between them flat. The center of the board is bandsawed down to 2 3/4".
The upper portion is two boards 30" long with a notch cut to ride on the lower section to follow the seat curve desired. Notch is 5"x 3/4" w/ a small board glued to the ends of the long boards. The two upper boards are spaced apart to 3 1/4". The center of this upper board is bandsawed down to 1 5/8".
You place the upper board jig onto the lower jig and let the router move by hand on the bevels and slide the upper boards over the lower jig bevel so you get the proper bevels of the seat.
Wish I knew how to send a drawing so you guys could see what I am speaking about. But it does work...at least for me.
We have success.......
I borrowed an angle grinder and fitted a four inch disk of 36 grit on it. I tried to buy a backer disk for it, but it did not fit, So I just took a shot with the abrasive disk by itself.
I drew out the shape in the seat and drilled a bunch of it away with forstner bits.. Sort of ragged at that stage, but the disk smoothed it out much quicker than I thought it would. I had brought about six of each, 36 and 50. They did not have any that were finer. It only took one of each. Then I sanded it out with my ROS. I did not time it, but it took over an hour and less than two. Of course, this is a small seat, the sculpted part is only about 9 x 9 and its walnut. I had no idea how long it would take, but it seemed to go better than I thought. Thanks for the help.
