OT ABS Light on
OT ABS Light on
OT  ABS Light on
Gary Smyth
Still on travel with a couple of new complications. First my 1994 vintage Honda muffler sprung a leak so that has to be replaced. Yesterday, the ABS dash light came on too. I suspect a bad sensor as it�s not the fluid levels and I do not see a leak anywhere. Since I can�t see the problem directly I�m looking for advice. I suppose I need to get to a code reader but I have no idea the cost of just getting a code reading. I do not have someone local here to trust for the cost of a reading, replacement, repair-- if that is the problem. Any one have a ballpark idea of the cost of a reading to check which ABS sensor might be bad. I can probably find a replacement sensor on the internet depending on which sensor is acting up, but is this a job for them or can I have the sensor sent home and I'll do the work? I�ll be home next week or week after. My tools (but only jack stands and NOT a lift) are available then.
Re: OT ABS Light on
Advance Auto Parts will
Gil Jones
Perform the OBD II code reading free, and give you the results.
Of course they would also like to sell you any needed parts too.
You also can buy the OBD II code reader at Harbor Freight for $50.
I have one, and it works great.
Gil
Re: OT ABS Light on
Mine is 1994  OBD II was later I think
Gary Smyth
Re: OT ABS Light on
I have the Harbor Freight reader
Stuart Hough
I believe it is backwards compatible with most foreign and domestic vehicles as far back as 1990. Additionally, if your ABS light is on it will most lilely be either the sensor on one of the wheels, or possibly the (I'm not sure if this is the correct term) attenuator valve unit that has gone bad. In either case, you still have brakes, just not the abs function.
Re: OT ABS Light on
Not a 1994
Dustmaker Mike
ABS was not hooked up to the PCM until around 2000 or so depending. ODBII came into being in 1996 if I remember correctly. I would not stop my vacation because of an ABS light on the dash It just means when you have to make an emergency stop the brakes will not pump for you, you will have to pump the brakes.
Now have you driven thru a lot of water or mud. There will be two wires heading into each brake caliper that is you ABS make sure they are tight and clean. If they are then you might just have a bad sensor which any good mechanic can find pretty fast. Good Luck Enjoy you trip.
Re: OT ABS Light on
Possibly Wheel Bearings
Rick Christopherson
I don't know anything specific about Honda (especially without a model name), but because it is front wheel drive, it likely has a sealed wheel hub with internal (non-serviceable) wheel bearings. The ABS sensor may also be located inside the hub to protect it from the elements.
When your wheel bearings fail, the metal filings interfere with the reluctor ring which confuses the sensor.
The ABS light is not what you need to worry about, because your brakes will still function without ABS control. However, this may be pointing to other problems, such as the bearings.
Re: OT ABS Light on
Re: I have the Harbor Freight reader
Tony - Memphis
Not sure about Honda, but the brakes aren't parto of the OBD stuff on my Chevrolet. It requires a different reader. My light came on years ago. Long story, but the quote was $1800! I replaced a sensor, but that didn't do it. Figured I'd try something cheap first. The dealer said the whole sytem was messed up. They work now and then. They charged the normal hour of labor to diagnose the problem which was around $75. None of the local parts places had a reader for brakes. I don't think they are a standard like OBD. I keep a OBD reader in my truck to clear out the various codes that consitently return. It's a 2001 S10 (my last Chevrolet!). Still going, but lot of issues....at least the air blows cold!
Tony
Re: OT ABS Light on
On the Fords the ABS started
Dustmaker Mike
to be read on the 2004 or 5 model year trucks. Before that they were best guess. Pretty much all the new stuff use a CAN bus for all the systems to talk and work together. That is how all this new traction controls and anti skid stuff work.
Mike I am not a mechanic by trade but I did sleep at a Holiday Inn last night(-;
