Automotive AC Question..OT
I had a frontal collision in my Honda CRV that caved in the front end. Guy hit me in an intersection at about a forty degree angle. That big black bumper on the front turned out to be a Big Rubber Nose and not much of a bumper.
Turns out the AC Condenser was ruined and a section of tubing was broken. I did the repairs myself and replaced the damaged parts. Had a local shop pull a vacuum on the system and install what ever they use for refrigerant these days. This was several months ago and as I recall they put nitrogen in the system to check for leaks and they pulled a vacuum and then put in the refrigerant. Worked fine until a couple of nights ago and it made a funny noise and croaked. It was still holding its charge.
Now they tell me the compressor seized and that they may be able to get away with just replacing the compressor, but that if it burned up and dumped oil and crud into the system, they will have to replace the condenser coil again.
I suspect that moisture got into while it sat in my driveway and that is what ruined it. I am just checking in here to see if all this sounds reasonable? $800 for the compressor and $300 for the condenser don't sound out of line but these are tough times. Any thoughts? What could I have done to prevent this? Or is it just time for an eight year old AC with 165000 miles on it to fail?
