Brushing shellac
Brushing shellac
Brushing shellac
Joe in a Cleveland suburb
Hello.
I have a couple small boxes made of curly maple. I applied a thinned coat of BOL, let it sit for a week, then started to brush on Zinser Sealcoat.
I've brushed on 4-5 coats now and sanded/leveled/removed brush marks, drips, and so on between coats.
I think now I need to do a final rub out - the last coat is not perfect. How should I do this. I want a gloss finish but it doesn't need to look French polished. Should I sand with something like 600 paper and lubricated with mineral spirits or something? Should I make a rubber charged with some shellac and alcohol and work it with that?
Edit: I should add these boxes are not completely assembled; the tops and bottoms are not attached so I have all flat surfaces to work with.
What do you all think?
I'm getting tired of messing with these little boxes and have put too much time into them, but one will be used as a pet urn so I wanted to try and make it nice.
Thanks.
Re: Brushing shellac
del schisler
i make jewerly box's and trinkit box's. All i do is use a sanding sealear. sand 400 grit than spray 2 coat's of lacquer and i am done. I can get this done in one day . i use M.L.CAMPBELL but i do lot's of them so far around 500 i would guess so i can't be doing more than i am doing now. They come out very good with not much work involved. I know you may not have a spray system . But i guess the next thing is rattle can's which i don't like deft ect. I would have went to a wipe on poly and could have saved some time?? good luck on the next project
Finishing
Hi Joe,
I'll Get from your post that you have flat surfaces (rather than profiled edged and moldings/trim) to finish. In that instance I use a very smooth block wet/dry SiC paper and a lubricant to level the top coat of shellac. Lubricant can be any oil (I don't use MS because of it being a VOC and I'd rather not be breathing it) but I prefer vegetable oil (canola, etc.). Start with 600 grit paper moving with the grain of the wood and continue until you don't see any shinny spots. Wipe the surface clean, and repeat with 800 and 1000 grit. The higher grits go very quickly, and you can substitute 0000 steel wool for the 1000 paper if you wish. You can now wrap your block with some lint-free cotton (T-shirt) and go to a medium rubbing compound. I use Menzerna now, but I used Meguire's auto-body compounds for years. Meguire's No. 3 Fine Cut Cleaner is the start with the final polish using their No.9 Swirl Remover.
HTH
m
Stephen Shepherd
Stephen Shepherd
Joe,
You might try dry brushing the surfaces with a wide brush lightly charged with shellac that has been thinned a bit. After most of the shellac is out of the brush then it is brushed quickly back and forth and produces a shiny finish. Takes a bit of practice but the technique can come in handy.
Stephen
Howard Acheson
Brushing is perhaps the worst way to apply shellac unless you have the right brush and some well-learned experience.
I would suggest you buy a couple of cans of Zinsser Spray Can shellac and apply your final coat from them. Spraying shellac is easy and will give you a very nice finish.
Stephen Shepherd
Stephen Shepherd
Howard,
I have to agree with you about brushing on shellac, not the best way, I just pad the stuff on, then French polish it out.
You can also thin shellac and spray it in a commercial spray gun or use a simple mouth atomizer [from art supply stores] and blow the stuff on with lung power.
Stephen
Thanks for the replies, Stephen...
can you briefly explain your polishing method?
Thank you.
Stephen Shepherd
Re: Thanks for the replies, Stephen...
Stephen Shepherd
Joe,
If you mean French polish:
8 inch square of linen
several cotton balls
Seed-lac [cheesecloth bag tied up and suspended in alcohol] quite thin maybe 1/2 pound cut or less.
non drying oil to lubricate the pad, fad or rubber
rottenstone for pad.
Slightly moisten the linen cloth with oil
Dip the cotton balls in the seedlac and squeeze out excess
Wrap in linen cloth and touch the pad to the rottenstone to get just a bit on
Keep the pad moving at all times while in contact with the surface
Work over area in circular motion.
Done
[I don't spirit out]
Stephen
