Questions on Tried & True Finish
Todd Nebel
Hello,
I'm building a tool chest from an article in a woodworking magazine and the author recommends using Tried and True Oil Varnish. The wood is curly cherry. First question is can I finish the inside of the chest with this? It looks like from the article's pictures that the author did. I typically would not use oil on the inside of a closed case since the smell lingers for a long while. Does the varnish allow you to? Next question is what to do between coats? The author says he sanded. The instructions say 0000 steel wool and burnish it. What's the recommendation here? Also, the instructions say to use a very thin coat. I found that hard to do on a test block. The product is relatively thick and requires a moist cloth to apply. Do they just mean wipe it well before moving on. That's my guess as the instruction says to come back in an hour and wipe it until there's no sign of product on the cloth.
Thanks,
Todd
. On my kitchen cabinets, I notice no smell at all. Having said that, if you want, use a coat of blond shellac on the interior to avoid odor problems. Personally, for a tool chest, I would not bother with shellac.
, this isn't a real problem for me. Hope this helps
