Between coat sanding, how much is enough?
Stephen Kirk
So, I'm finishing a pair of chairs with lots of nook and crannies (good for butter!) between the slats and rails and such. I'm spraying on General Finishes Water Based Pre Cat Urethane. When its recommended to sand between coats, is hitting every last spot really necessary, or would you stick with major areas and skip the rest. For my chairs - arms, seat rails, exposed slat surfaces, legs. Otherwise, it's a rarely touched or seen area.
What do you think, minimal sanding to get the coats on, or get detailed and make every last inch perfect? I should also add this is a commission project, but I'm not charging all that much.
By the way, this is my first sprayed project, and I really like spraying. As my technique improves, hopefully I lay down better and better surfaces with little need for sanding. The sealer was water based, so it did raise the grain, but that shouldn't happen on later top coats.
Re: Between coat sanding, how much is enough?
Dick Coers
I'm not familiar with that product, so I suggest a call to them. Some materials need the sanding to have a mechanical bond. Others melt into the previous coat, so they have a chemical bond. I suspect you will need the mechanical bond. Now to me, sanding between coats can be misleading to a beginner. Wiping with sandpaper is more appropriate if there is no issues with the coat of finish.
FredD
You owe it to your Customer to do the best you can ,both with the Assembly and the Finish.
How much you charge or even if it's free should not be the factor governing the quality of the Finish, but rather your pride in your work.
People who do a bang up assembly and then cut corners on the Finish leave a sample of their work for everyone to comment on.
Sand all of the finish to eliminate over spray and next project , maybe think about a better finish that lends itself to ease of application ,, like Solvent Lacquer for instance
FredD
paul in AZ
If the varnish is pretty decent and all you want is to slightly rough it up for adhesion, some fine [4-O] steel wool gently applied will knock the surface sheen off. In some ways easier to control than sand paper. Use a tack cloth to not only clean up any dust but to pick up any fragments of steel.
I've taken to using abrasive pads for "sanding" between coats. I usually use gray (000) or maroon (00). I find they leave less residue.
Clint Searl
Clint Searl
I agree; solvent lacquer would be my choice for that kind of job. Or even a wipe-on poly.
Clint
Stephen Kirk
First coat was the sealer, which raised a lot of grain, and I expected to do some sanding. I'm hoping the subsequent coats on well and only need a light sanding.
Stephen Kirk
I was considering a wipe on poly, but I have a lot of open bits to get into so I opted for spraying.
I also considered solvent lacquer, but I didn't want the extra chemicals around. So, I'll live and learn and see how this type of finish goes.
Moses Yoder
Re:Only sand the parts you want smooth
Moses Yoder
Stephen Kirk
Hahaha, love it!
Never use steel wool with water-based
Dick Coers
Nor tack cloths either. If you want to use a soft pad to work the finish, use a synthetic pad. Traditional tack cloths may lead to poor adhesion, steel wool can discolor (rust) with the next coat.
Couple things
There are a couple reasons to sand, as people have already said, and like Dick, I think you will need to sand your pre-cat urethane product to facilitate adhesion of subsequent coats. Such products don't partially dissolve under the next coat; they need some mechanical "tooth" which you must provide with sandpaper.
So, adhesion is one thing, but another important reason to sand is to achieve a flatter surface. Most finishes raise a little fuzz or nibs, and waterborne finishes are famous for that. Also, whether you brush or spray, there is always the likelihood of some surface irregularities, whether it be brush marks or sags and drips. These should be leveled somehow prior to proceeding with the next coat. Light and careful sanding with fine sandpaper on a flat sanding block will help flatten these surface imperfections. You might need chisels or a scraper to remove major drips, as sandpaper tends to sand around them, causing another kind of problem.
So, if your hard-to-reach areas are aesthetically important to the overall piece(s), I'd consider finding a way to flatten them carefully as you would any other visible or tactual feature. If you just need to kill the gloss and rough up the surface a bit, go for the synthetic wool abrasives or even Scotch-Brite�. Soft products like steel wool and non-woven pads aren't very good for creating optically flat surfaces.
