We value your privacy.
I know the simple method for radiusing (if that's a verb) a 90-degree corner but is there a different method for creating a radius for an acute or obtuse angle?
I'm building a triangular table with two 45-degree angles and two 135-degree angles. Basically, a pyramid with the very top portion cut off so it's parallel to the base. If I can't radius the 135 degree angles, it's not a big loss since they won't be very visible but the 45-degree angles are very visible.
The table top is the triangle, not the base of the table.....if that confused anyone. It's a TV stand that will be in a corner, hence the general 90-degree triangle shape.
Think of it this way: the more obtuse the "corner" angle the larger the radius of the radius; i.e. the radius of the radius of a 180 degree angle would be infinite. Whatever looks good is my rule.
A quick-and-dirty approach would be to collect a bunch of circular objects of various diameters [paint cans to medicine containers], trace out the radii on each corner and pick those that look best to you. I don't know of a mathematic formula.
Same here. I save all sizes of jars to use when I have to mix up chemicals or save something. The lid or jars themselves become circle jigs whenever I need one. Paint and spray paint cans also work well. Worse case scenario I draw the circle I need with a compass and cut it out on the scroll saw, then sand it perfect. These are usually used with the router and guide bearing.
Nat, for the 45� angles, can you cut the pieces at 90�, cut the round-over, then, tangent to the round-over, cut the additional 45�, and sand the bump ? That's what I do when I need to radius an acute angle.
Draw a line bisecting the angle, then use a compass with the point on that line and just experiment with various radii until you find what looks good to you.
Nat, I confess, I would benefit from some kind of visual here. I don't know if you're talking about radiusing the beveled edges of this table top or the points of the triangle. Assuming you mean the edges, I would sharpen up my best block plane and round those edges by hand. It would take only a little while, and you can dial the curve in by degrees to the look and feel you like best. Finish up with sandpaper wrapped around a scrap of leather. Routers are not very useful for this, nor necessary.
If you're talking about the points, as several people are assuming, I'd just go with the trace-the-paint-can- lid idea and see what radius suits you.
I guess there's another possibility in your question, that you want to continue the sloped edge around a radiused corner on this trianglular top. Depending on how much wood you need to remove, you might do this with saws, chisels and rasps, making the final surface with smooth files and/or sandpaper on a hard sanding block.
For the life of me, I cannot read this post and make heads or tails of what you are talking about. A picture would be worth a couple government trillions worth of words.
