Interesting article - Ancient protractor *LINK*
Craig Daymon
Saw this article in the news today about the discovery of an ancient Egyptian protractor. Thought I'd post it here in case anyone had plans on building a pyramid.
Look at the second picture (click on "1 more image" under the picture) to see how it was thought to be used.
-Craig
Ancient Egyptian Protractor found
Re: Interesting article - Ancient protractor *LINK*
Interesting.
I'm struck that the surface that was thought to be the bottom is rounded, so it'd be inclined to fall over in use - you'd need multiple hands to use the thing.
Later thoughts *LINK*
Funny what you think about while painting (exterior trim, in this case).
First, the physicist who proposed this is describing an inclinometer, not a protractor, isn't she?
It seems like an awfully complex way to get there, when it would have been just as easy to scribe angle marks on the A-frame device used, with a plumb bob, to establish level. Of course, it would not be the first time someone's initial solution to a problem was more complex than it had to be (I've been known to do that myself...).
I found the original paper (or an English translation of it), linked below. One interesting digression in it: one of the cubit rods found with this object is hinged to fold up: the original zig-zag rule!
http://arxiv.org/pdf/1107.4946
