For those with air filtration systems?
Do you ever use charcoal filters to minimize/absorb the odors from staining?
In this hot weather, I'd rather not open up my shop space. Air conditioning is a wonderful thing.
Re: For those with air filtration systems?
No.  I Was Told
That the charcoal filters were not worth the cost trying to get VOCs removed from the air, plus, unless you put the unit right next to the wet surface, they weren't that effective, and then you have to worry about ignition because the air-cleaner units are not "explosion proof" unless you shell out some very serious ($1,200 and up up up) coin.
If I have staining or solvent finishing to do, I take the piece outside or to the garage (vehicles get removed).
I wouldn't try it at home due to the cost. I designed, built and used a charcoal filter system in the plant where I worked as an Engineer. Maintenance fabricated a frame to hold standard large furnace filters, then behind the standard filters we installed a carbon filter about 4" thick. Then we installed a squirrel cage fan to pull all the air entering the booth through the filter. This was a freestanding Airbrush booth used to paint small plastic light pipes. I purchased the activated carbon in 55 gal drums. Depending on the work load the filter had to be emptied and refilled in 1 week to one month. The interval was determined when operators near the station began to smell the solvent. The unit worked well and was used for a couple years, but the cost to maintain it was way beyond was would be feasible for a home shop. Remember the carbon filter was about 25 X 25" and 4" thick - a LOT of fairly activated charcoal, and the amount of solvent trapped was probably less than 1 pint total between recharging.The only reason we didn't vent the booth was that we were having trouble with roof leaks on the about 1/2 acre of flat roof so it was ordained no further holes were to be made through the roof.
