Answer for Rick
On the side of the unit there is a thumb screw that holds the hatch. Unscrew and the hatch comes off.
Just slide the filters out.
I do it when I remember
to check them which is usually every three months or so
. How often you clean them depends on how much run time and how dust you're producing. If you're like me and run dust collection on sanders (plus on all the machines, of course) in a hobby shop. 2-3 months is probably a good interval.
BTW, I should note that in blowing out the bag filter section, you don't want to be going at it with 125 psi air as you'll risk tearing the filter. That'll be a $50 mistake which is what JDS likes to charge for their filters. 30 PSI is enough to blow out the fine dust or you can use a shopvac in blower mode.
