I have the Jet too...
John in NM
Same one as Mark. Works fine for the size and I like having a dedicated set up for simple mortises. If it lacks anything it's a positive holding arraignment, but I don't expect that for the price really.
Mortiser chisels wear in btw, they'll be awful for a while, but then the inside of the chisel gets smoothed up through use and they start working really well. You can sharpen the chisels with stones of any flavor and the drill with a small triangular file.
I also turned mine around on the base to gain some more height. Work surface is now a couple of ipe battens that the base is screwed to.
I think Delta and Powermatic sell clones of this machine too, but it's been years since I was in the market so I may be mis-remembering.
