OT Car Laptop Charger *LINK*
Stuart Johnson
We would like to use the laptop while driving but the battery isn't the best and doesn't last long. It's old and I don't want to purchase a replacement for just occasional use. Am I reading what this plug does correct? It appears this is plugged into the cigarette lighter and produces enough AC to plug in the normal battery / ac pack for charging or normal use. It also seems to have a USB port for cell phone or camera charging.
Lap Top Charging Inverter
Re: OT Car Laptop Charger *LINK*
woodenleg
I have one that looks to be the same style. We used it in rental cars in Hawaii. It worked just fine except when the battery was really low on the laptop. We have since used it on our own rigs, just make sure you plug it into a source that is shut off when the key is off. We did not do that on a trip to town and the car really didn't want to start. Dave
John McGaw
I've used a small 12VDC -> 120VAC inverter for charging a laptop and similar tasks and it worked fine for me. My concern with the unit you referenced is that the power output at 75W (claimed) might be a bit low if simultaneous charging/running of an older power-hungry laptop is attempted. Additionally, the unit looks to be a bit bulky and it might be a tight squeeze in some cars. My Subaru has three 12V power (cigarette lighter) outlets and I'm fairly certain that it wouldn't fit in two of them.
Rick Haverstock
Stuart,
On our boat we use a laptop as a navagation computer and use a 12Volt to 19V comverter for our Toshiba Satellite (also older and power-hungry). Bought it from Amazon and IIRC, it was around the same price, maybe $5-10 more. Be sure to read the label on your brick power supply. Our laptop AC power supply draws 150 watts at 110 VAC. Converting from 12 volts DC to 110 AC back to 12-19 volts DC for the computer is not a very efficient way of doing things. I also noted that the AC output on your Amazon link was modified sine wave, not true AC. Many small appliances do not likie MSW power and your laptop may go on strike and refuse to work for you.
Rick Haverstock
